Whirlpool W10200828B Not filling up
17 replies to this topic
#1 rkovelman
rkovelman
  • 13 posts
  • Flavorite Brew:None
Posted 19 January 2015 - 12:10 AM
Hello,
I have a Whirlpool, W10200828B, washing machine.  I recently had to disconnect it to redo my floors.  Upon reinstallation I ran it on soak to ensure there was no leaks from the hot and cold side.  All was great.  Now I want to run the machine in "Regular" cycle and it will not fill up at all.  Odd!  I decided to make sure all was okay and ran the machine on "Spin" cycle, and no issues.  Seems the spin cycle is the only one that works.  Am I correct in that the machine still has water in it and will not fill or run in "regular" cycle until the water is emptied out from the "soak" cycle I ran?  I do not see any water in the machine where the cloths go.  After running the "spin" cycle for like 10-15 min the cloths that were in there are somewhat dry.  Any ideas on what is going on?
Thank you
#2 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 881 posts
  • Flavorite Brew:yeunling
Posted 19 January 2015 - 07:51 AM
Thats not the model number
#3 rkovelman
rkovelman
  • 13 posts
Posted 19 January 2015 - 12:43 PM
That is what the manual says on it
http://www.manualsli...28b-428945.html
Is there someone where I should look for the model?
#4 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 881 posts
Posted 19 January 2015 - 12:51 PM
Inside the door or lid
#5 rkovelman
rkovelman
  • 13 posts
Posted 19 January 2015 - 01:16 PM
Is this it?
W10140920d
#6 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 881 posts
Posted 19 January 2015 - 02:28 PM
No, it should be wtw or wfw and then numbers
#7 Dan Webster
Dan Webster
    Paw Paw
  • 1,395 posts
  • Flavorite Brew:Freebies
Posted 19 January 2015 - 03:29 PM
I did and overnight leak test on one of the newer ones with the lights on it below the timer knob. I had to put it on spin to get the water to pump out.
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a beer through paypal: dannywebster@ymail.com
#8 rkovelman
rkovelman
  • 13 posts
Posted 19 January 2015 - 04:08 PM
sh2sh2 - wtw or wfw does not exist on that sticker.
Dan - How long do we need to make it run on spin cycle?
#9 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 19 January 2015 - 04:19 PM
You're giving a part number, which could be the part number for the manual, the serial tag or anything I haven't looked it up to see what it is, but it's definitely not a model number.
Actually it's the part number for the Use & Care Guide.
It goes to one of these Model Numbers, Open the lid and look under the lid on the cabinet, there it will be revealed.
Whirlpool1CWTW5200VQ1AUTOMATIC WASHERWhirlpool1CWTW5300VW1AUTOMATIC WASHERWhirlpool1CWTW5590VQ1AUTOMATIC WASHERWhirlpoolWTW5100VQ0AUTOMATIC WASHERWhirlpoolWTW5100VQ1AUTOMATIC WASHERWhirlpoolWTW5100VQ2AUTOMATIC WASHERWhirlpoolWTW5200VQ0AUTOMATIC WASHERWhirlpoolWTW5200VQ1AUTOMATIC WASHERWhirlpoolWTW5200VQ2AUTOMATIC WASHERWhirlpoolWTW5300VW0AUTOMATIC WASHERWhirlpoolWTW5300VW1AUTOMATIC WASHERWhirlpoolWTW5300VW2AUTOMATIC WASHERWhirlpoolWTW5505VQ0AUTOMATIC WASHERWhirlpoolWTW5505VQ1AUTOMATIC WASHERWhirlpoolWTW5590VQ0AUTOMATIC WASHERWhirlpoolWTW5590VQ1AUTOMATIC WASHERWhirlpoolWTW5600VQ0AUTOMATIC WASHERWhirlpoolWTW5790VQ0AUTOMATIC WASHERWhirlpoolWTW5790VQ1AUTOMATIC WASHERWhirlpoolWTW5790VQ2AUTOMATIC WASHERWhirlpoolWTW57ESVH0AUTOMATIC WASHERWhirlpoolWTW57ESVH1AUTOMATIC WASHERWhirlpoolWTW57ESVW0AUTOMATIC WASHERWhirlpoolWTW57ESVW1AUTOMATIC WASHERWhirlpoolWTW58ESVW0AUTOMATIC WASHERWhirlpoolWTW58ESVW1AUTOMATIC WASHER
Edited by Spannerwrench, 19 January 2015 - 04:20 PM.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#10 rkovelman
rkovelman
  • 13 posts
Posted 19 January 2015 - 05:16 PM
WTW57ESVW1 found it...
#11 Dan Webster
Dan Webster
    Paw Paw
  • 1,395 posts
Posted 19 January 2015 - 06:43 PM
looks like your washer has the same screwy switch on it as the one i am working on lol
-old Irish saying
#12 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
That's pretty much just a basic direct drive unit when they started trying to get energy efficient.  If the unit is drained, make sure that the shut-off valves are opened, if it still doesn't fill this is most likely the problem.
Part number: AP4459660
Edited by Spannerwrench, 19 January 2015 - 06:45 PM.
"Suds are not good"
#13 rkovelman
rkovelman
  • 13 posts
Posted 19 January 2015 - 09:22 PM
The part is like 70-80 bucks.  My only issue is, is this the part that broke?  Not sure if there is a way to test this?  And if so, once replaced how much longer will the unit last?
Also did it go bad from me moving it?  Or just age?  Not sure if anyone knows when this was made?
Thanks!!
#14 Dan Webster
Dan Webster
    Paw Paw
  • 1,395 posts
Posted 20 January 2015 - 01:00 AM
They had a rash of bad temp switches when it first came out that looked like this un.
-old Irish saying
#15 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 31,390 posts
Posted 20 January 2015 - 08:31 AM
If you buy the part from the link posted above and it doesn't fix the problem, you can return it for a refund. It's a risk-free as you can get in a risk-filled world!
#16 rkovelman
rkovelman
  • 13 posts
Posted 20 January 2015 - 11:18 AM
Part is ordered...
#17 rkovelman
rkovelman
  • 13 posts
Posted 21 January 2015 - 09:42 PM
That worked.  Thanks all!  PS: http://www.appliancepartspros.com/is the best.  Received it within a day!
#18 Dan Webster
Dan Webster
    Paw Paw
  • 1,395 posts
Posted 21 January 2015 - 11:11 PM
glad ye could git her did hope mine gets fixed i ordered a timer
-old Irish saying
