GE TFX25ZPZBWW
ice/water dispenser problem
2 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 402 posts
  • Flavorite Brew:Coors Light or Vodka
Posted Today, 05:52 PM
This machine has been a real headache... the short water harness with an attached relay and the primary water valve were replaced because they were bad. I don't know what caused the relay to go bad but the valve had a crack in the body and was leaking! Now the water dispenser is not dispensing water. Can anyone tell me where to look next???  Pleaase tell me it's not the control board... Thanks for your time
Edited by richseattle56, Today, 05:54 PM.
#2 BryanS
BryanS
  • 1,388 posts
Posted Today, 07:55 PM
Are you getting voltage to the water valve? Is this the water valve with half a million water line connections? Were the lines put back in the correct spots? I can't say I ever had one of the dispenser boards bad but if it controls it and you aren't getting voltage out of it that would be my guess. I don't recall ever seeing a relay on those water valves but I haven't messed with very many of this model. Obviously, if it is getting voltage, then you would have to start unhooking lines to find out where you are losing it.
Edited by BryanS, Today, 07:56 PM.
#3 richseattle56
richseattle56
    Kohai
  • 402 posts
Posted Today, 10:59 PM
I have an update tonight... the ice maker started kicking out ice good and steady, so I must have the tubing right! The only problem now is that the water dispenser isn't putting out. My Brother suggested a frozen water line within the freezer door. So I guess I'll defrost again and see if that solves the problem...  I'll double check for voltage in the morning and yes this model has 5 water connections!!!
Thanks for your reply and I'll post my results
1 members, 0 guests, 0 anonymous users
