Whirlpool Duet Washer Model #WFW9450WWOO
4 replies to this topic
#1 bogreen
bogreen
    Kohai
  • 499 posts
Posted Yesterday, 09:39 PM
Hi,
This unit doesn't seem to be getting enough water in.
After the wash cycle, before rinse, the customer reports an F20 error code.
I ran the diagnostic test.
The unit filled with water, but not enough I thought, then the tub rotated clockwise as the sheet said.
But it also started to rotate CCW??
Then it drained fine and went into the spin cycle which it should have reached max rpms in about 15 seconds.
It was spinning at slow speed for about 10 seconds and then everything shut off.
Any ideas??
Bruce
#2 weswayne
weswayne
    Sōhei
  • Chief Appliantologist
  • 119 posts
  • Flavorite Brew:Coke
Posted Yesterday, 10:49 PM
Start with making sure the inlet hoses are clear and the inlet valve screens are not all crudded up with gookus. Check the inlet valves themselves then maybe the pressure switch and pressure switch hose. Good start anyway. :kopkrab:
#3 bogreen
bogreen
    Kohai
  • 499 posts
Posted Today, 01:27 AM
So, basically the Diagnostic test tells us nothing really relevant??
What's the point of it's use?
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,508 posts
Posted Today, 05:07 AM
see both http://appliantology.../?hl=+duet +f20
and
www.DurhamApplianceThrift.com
#5 PDuff
PDuff
  • 2,040 posts
Posted Today, 12:36 PM
Slow fill could still be an issue, especially the cold water side of the inlet valve.  But the fact the unit drained completely but didn't spin properly in the component test could indicate a problem with the pressure switch and/or hose.
0 members, 1 guests, 0 anonymous users
