Simpson washing machine troubles
#1
Guest_katy_4575_*
Posted 13 May 2005 - 02:37 AM
#2
Posted 13 May 2005 - 05:15 AM
Basically, beacuse the tube was disconnected, the switch hasn't pressurized correctly to sense that the tub is full. Empty it, start again and you should be OK. The humming noise is the water valve operating but it can't get any water.
#3
Guest_katy_4575_*
Posted 13 May 2005 - 01:16 PM
Yes I am from Australia. I thought this might be the case but knowing next to nothing about washing machines thought I might be way off track so I decided I had better ask first. The Repair Clinic Guru, who I also sent my enquiry to said water probably got on the motor when the machine overfilled so heres hoping your right. Thanks again.
#4
Guest_readnik_*
Posted 13 September 2005 - 11:55 PM
#5
Posted 14 September 2005 - 05:37 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
