Electrolux FS FGEF308TNFB Code:68 Part 2
6 replies to this topic
#1 Anthony
Anthony
    Ikkō-ikki
  • Chief Appliantologist
  • 26 posts
  • Flavorite Brew:Dark & Tan
Posted 18 March 2015 - 12:42 PM
I found an article about the same model #, same conditions.  They had a crew of Frigidaire techs & electricians.  They replaced the control 3x & touchpad once (?).  Frigidaire put an inline filter on the block, but it doesn't say if that corrected the problem.   CK1402 is a bulletin related to electrical noise problems, doesn't include my model # though...  Will continue to search>>>
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 18 March 2015 - 01:23 PM
I had one of these that kept having problems a couple of weeks ago.  We've been replacing the board for various reasons, contently heating in the small oven, sometimes the light doesn't work, sometimes the clock resets or doesn't keeps time, and the last one shuts down during cooking.  I called tech line to see if the pointer also applied to this model since it's similar, they said yes they just haven't updated the service pointer.  They haven't updated the control kit part number yet either for this model, so you have to replace the control and filter board separately.  I've got the number written down somewhere I'll try to find it.
By the way the manual I posted does not apply to this model.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#3 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 18 March 2015 - 01:37 PM
Here's the filter board part number, Electrolux also recommends replacing the electronic control at the same time.
Part number: 316303501
Edited by Spannerwrench, 18 March 2015 - 01:38 PM.
"Suds are not good"
#4 Anthony
Anthony
    Ikkō-ikki
  • 26 posts
Posted 19 March 2015 - 01:16 PM
One of the other techs ran the callback while I was out.  He switched L1 & L2 (??, heck, why not...)  No word back, been 4days, maybe the customer gave up (??)  I'll call them this week & check how things are working.
Nice networking guys.  I appreciate the effort :thumbsup:.  I figured it was a engineering glitch they hadn't caught up to yet.
Thank you for the part number.  I'll get the filter, control & a prayer for these people.
#5 Anthony
Anthony
    Ikkō-ikki
  • 26 posts
Posted 23 March 2015 - 10:05 AM
Called customer, still acting up.  Will install fix & post.
#6 Anthony
Anthony
    Ikkō-ikki
  • 26 posts
Posted 14 April 2015 - 11:58 AM
Still waiting for customer to schedule.  Go figure.
#7 Anthony
Anthony
    Ikkō-ikki
  • 26 posts
Posted 29 April 2015 - 10:29 AM
Installed harness & board a week ago.  Called customer last night.  All is good.
