Wolf oven SO30F/S - relay stuck
No replies to this topic
#1 LI-NY Tech
LI-NY Tech
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 810 posts
  • Flavorite Brew:Virgil's Cream Soda
Posted Yesterday, 05:05 PM
Customer has a Wolf wall oven SO3F/S, serial 11082735.
The display is intermittently showing "relay stuck" on bake cycle after about an hour of cooking.
The display is intermittently showing "relay stuck" on bake cycle after about an hour of cooking. Service manual simply says to repen how often relays fail. Service manual simply says to replace relay board. Looks like the only two possible causes are the relay board or the oven controller board. The controller has a current sensor that detects this problem.
Seems like the relay board is most likely the cause given how often relays fail. Aside from breaking open the relays to check them physically is there any other way to test this besides just catching it happen and then testing the circuit?
Edited by LI-NY Tech, Yesterday, 05:05 PM.
David
RD Appliance Service, Corp.
PO Box 234, Bethpage, NY, 11714
516-561-0523
http://www.rdapplianceservice.com
