Kenmore Electric Dryer Model - 110.86160800
#1
Guest_Fred_*
Posted 13 May 2005 - 10:11 AM
At this point, I'm not sure if it is the switch, the timer or the motor. I don't hear the motor at all, so I just don't know what to test next. Any help and/or suggestions on what I might try to isolate the problem further?
Thanks in advance for your help.
Fred
#2
Posted 13 May 2005 - 12:29 PM
#3
Posted 13 May 2005 - 01:19 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#4
Posted 13 May 2005 - 01:27 PM
Dayyam, how'd I miss that his element was staying on? :beating:You MUST see why this element is coming on without the motor running. You have a very dangerous situation there which could catch the dryer on fire. Look at the heating element to see if the coil is touching something metal, and GET THAT DRYER UNPLUGGED!!!
Fred, are you saying the element is staying on even with the dryer off?
#5
Guest_Fred_*
Posted 13 May 2005 - 01:38 PM
No, the heating element is only coming on when you turn the timer to one of the sections where heat is applied during the cycle. But, as soon as I turn the timer knob to that section, the heating element is coming on without even pressing the on switch. That's why I wasn't sure where to go with this. It's very strange, at least to me.
I'll check and see if the element (coil) is touching something metal.
Thanks and if you think of anything else in the meantime, I appreciate any other ideas you might have.
Regards, Fred
#6
Guest_Fred_*
Posted 13 May 2005 - 01:54 PM
I've unplugged it and will take it apart once the heat element has cooled a little. I'll update you and/or ask more questions then.
Thank you again!
Fred
#7
Posted 13 May 2005 - 06:45 PM
#8
Guest_Fred_*
Posted 14 May 2005 - 07:19 AM
You were absolutely correct. When I pulled out the heating element, one of the coils was in fact grounding on the frame of the element. This may have been like this from when it was replaced several months ago. I'm sure a seasoned professional would have known to make sure all the coils were attached to the frame appropriately, but I didn't even notice that one of the sides was touching the outside frame (makes perfect sense now).
Okay, now that I fixed that the heating element isn't coming on at all. Which according to your message that's the way it's suppose to work and only come on when the motor is running. Now, I'm even more lost as to what to check next. I checked the thermostats for continuity and they all seem fine. Is there a fuse somewhere that I need to check?
Now when I press the start button, still nothing happens, but I can hear the timer working (or so it appears).
Thanks for any other suggestions, I really appreciate your help very much!!!
Fred
#9
Posted 14 May 2005 - 07:34 AM
#10
Guest_Fred_*
Posted 14 May 2005 - 08:46 AM
Thanks. It was the fuse, so I'm off to get a replacement. I'll update you further once I have it reinstalled and everything back together, but it's looking good.
Thanks again for all of your help.
Fred
#11
Guest_Fred_*
Posted 14 May 2005 - 10:44 AM
Thank you both! My dryer is working correctly again and all the thanks go to you two. My wife passes along her gratitude also.
Thanks for solving another mystery of the universe. :D
Good luck to you both.
Fred
#12
Posted 14 May 2005 - 02:57 PM
Now go git you a cold one. :guzzle:
#13
Posted 14 May 2005 - 08:05 PM
