Fisher and Paykel DD602 Lid Seal
6 replies to this topic
#1 maty3387
maty3387
  • 3 posts
Posted 17 April 2015 - 07:43 PM
Hi all,
Just moved in to a place with the Fisher and Paykel DS602 single drawer dishwasher. After reading the owner manual, it is stated that "you may notice a delay after the Start / Pause button has been pressed. During this time the lid seal will be inflating." However I am not sure if the delay on mine is "normal". How long should it take for the lid seal to inflate?
Should the lid seal should only take a few seconds to deflate when pausing the drawer mid cycle?
Cheers
#2 weswayne
weswayne
    Kohai
  • Chief+ Appliantologist
  • 314 posts
  • Flavorite Brew:Coke
Posted 17 April 2015 - 09:02 PM
At the beginning of each wash cycle, the lid seal inflates while the pre drain cycle removes
any residue water from the tub. This runs for approximately 60 seconds, then the tub fills.
At the end of the dishwasher programme, or a pause in the programme, an exhaust valve
releases the air pressure from the bellows section gasket. This deflates the seal and
unlocks the tub and drawer.
#3 maty3387
maty3387
  • 3 posts
Posted Yesterday, 01:22 AM
So does that mean it will take 60 seconds to inflate?
#4 weswayne
weswayne
    Kohai
  • 314 posts
Posted Yesterday, 10:11 AM
Yes. That is the information straight from the manual.
Edited by weswayne, Yesterday, 10:12 AM.
    Shōgun
  • Master Samurai Tech
  • 30,522 posts
Posted Yesterday, 01:46 PM
Although the actual lid seal inflation process may not require 60 seconds, the entire pre-wash process is 60 seconds long. If it's taking much longer than that, then the inflatable lid seal may have a leak.
You can place the control into diagnostic mode and separately inflate the lid seal to check for leaks. The service manual has the procedure: http://appliantology...-service-parts/
#6 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • 1,025 posts
Posted Yesterday, 01:57 PM
My question is, Why are you timing it? Run the dishwasher if it doesn't leak it's fine. You may be looking for a problem when there isn't one.
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#7 maty3387
maty3387
  • 3 posts
Posted Today, 12:58 AM
Thanks all for the info. You're right there, if all is good why question it. It's just that I've never experienced using this type of dishwasher before and as it is different in both form and function, there are certain things that I am questioning about its method of operation.
