LG Refrigerator LRCS26822TT Not Freezing
7 replies to this topic
#1 ancel1961
ancel1961
  • 17 posts
  • Flavorite Brew:Coffee
Posted Yesterday, 08:51 PM
I have a side by side, LG refrigerator / freezer which is not freezing.
Model number LRCS26822TT
The refrigerator section is working fine, but the freezer section's temp. will not go below 38 degrees regardless of what temp. setting I put it on.
The fan is blowing in the freezer, and I've tried the ''Express Freeze'' option.
No error codes are being displayed.
Any help would be greatly appreciated
#2 weswayne
weswayne
    Kohai
  • Chief+ Appliantologist
  • 330 posts
  • Flavorite Brew:Coke
Posted Yesterday, 08:55 PM
Double check that model number
#3 ancel1961
ancel1961
  • 17 posts
Posted Yesterday, 10:14 PM
I'm sorry. The correct model number is LRCS26922TT.
#4 weswayne
weswayne
    Kohai
  • 330 posts
Posted Yesterday, 10:28 PM
LRSC26922TT
#5 weswayne
weswayne
    Kohai
  • 330 posts
Posted Yesterday, 10:33 PM
Is the compressor and condenser fan behind the fridge running while the evaporator fan in the freezer section is running?
#6 ancel1961
ancel1961
  • 17 posts
Posted Yesterday, 10:51 PM
Yes both are running, but the compressor cycles on and off faster than other refrigerators that I've had in the past.
The compressor runs for around 2 minutes before it cycles off
#7 weswayne
weswayne
    Kohai
  • 330 posts
Posted Yesterday, 10:58 PM
You may need to remove the evaporator cover and see what type of frost pattern is on the evaporator, if any. Post a picture if you can.
#8 Applianceman97
Applianceman97
    "Hollywood"
  • 2,459 posts
Posted Today, 12:34 AM
Check the thermistor value from the main board. I'm assuming you have the tech sheet. The test point should be listed there.
When the compressor turns off after 2 minutes, I'd there still voltage being sent from the main control?
