Kitchenaid KSCS25INSS00 compressor cooling fan not working
cooling fan
7 replies to this topic
#1 rsm1141
rsm1141
  • 3 posts
  • Flavorite Brew:Hefe
Posted 23 April 2015 - 04:29 PM
Compressor running and fan is not.  When I plugged the refrigerator in, the fan turned about 1/8th turn and stopped.  Checked voltage to fan and there was none.  Pulled fan, checked at appliance repair shop and it's operational.  Checked internet and it appeared to be the main control board.  Ordered a repaired board-original board P/N 2306988- and got replacement board P/N 2307037 which is supposed to be the latest board for this unit.  Installed new board and same problem-plugged in refrigerator and fan turned about 1/8th turn and stopped.  Checked voltage to fan and again there is none.  Any Ideas???
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,787 posts
Posted 23 April 2015 - 06:23 PM
That's because you replaced the display board, instead of the mainboard...p/n W10219463
Part number: AP4411082
The dead giveaway is you said you bought a rebuilt board instead of having your board rebuilt... Finding a rebuilt mainboard for sale for this part number is next to impossible... Although if patient or lucky, you may find one between $500 - $900. So you have to have yours rebuilt
Edited by DurhamAppliance, 23 April 2015 - 07:03 PM.
www.DurhamApplianceThrift.com
#3 rsm1141
rsm1141
  • 3 posts
Posted 23 April 2015 - 11:58 PM
Is the Main Board the inverter board?? If not, where is the main board located? My inverter board P/N is or Part number: W10629033
. All Kitchenaid schematics show no "main board".
#4 johntech
johntech
    Wigwagin Dragon
  • 384 posts
  • Flavorite Brew:Coke
Posted 24 April 2015 - 06:48 AM
An inverter board controls motors, also called mcu or motor control board. It tells compressor what to do. The main board on yours I belive is attatched to the bottom of the unit. You should be able to see it if you lay on the ground and pull off the front vent panel.
#5 johntech
johntech
    Wigwagin Dragon
  • 384 posts
Posted 24 April 2015 - 06:54 AM
It listed in the parts break down under the unit parts
#6 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • 1,048 posts
Posted 24 April 2015 - 01:16 PM
That doesn't mean it's the one that controls the unit, the 'Unit Parts' means that the parts listed are in the compressor compartment generally.
You need the Electronic Control which is no longer available and must be sent to get rebuilt.
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#7 rsm1141
rsm1141
  • 3 posts
Posted 25 April 2015 - 01:09 PM
Thanks-found the board hidden on the left back next to the inverter control unit.  Sure wish the schematics would show where parts really are!!!
#8 lvasquez11
lvasquez11
    Sōhei
  • 237 posts
Posted Yesterday, 11:02 PM
did you get control repaired yet
Also tagged with one or more of these keywords: cooling fan
