GE PFS22MISBBB changing thermistor in FF section
6 replies to this topic
#1 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 993 posts
  • Flavorite Brew:orange juice
Posted Today, 09:10 AM
I got the manual and tested the thermistors.  The test (I think) shows two bad.  It showed 0-2 and 0-5.  The fridge is freezing ok in the bottom freezer and the damper seems to work when tested but the fridge section is warm 65 degrees.  I know you can test the thermistors at the board  J3  but I can't find which wires to check and I can't see how you are supposed to change the one in the top of the FF section.  I could use some help on this.  I can get it out but it has no wire to play with and no space to put it back in with a new one spliced in with but connectors on it.  Is there a trick to this.  Also the o-2 and 0-5 show open thermistors but I don't know which ones they are and can't find any  reference as to which one is 2 and which one is 5.  The others check ok 1,3,4 have a P.  Could someone point me in the right direction.  This is a french door GE bottom freezer.
thanks
Doc
#2 weswayne
weswayne
    Kohai
  • Chief+ Appliantologist
  • 363 posts
  • Flavorite Brew:Coke
Posted Today, 10:14 AM
You have tech sheet 31-51651?
The refrigerator diagram show 3 locations only.
The wiring diagram shows 3 thermistors. FF pin 1, FZ pin 3, EVAP pin 4 at Plug J1 (looks like J1). J3 is the damper
#3 weswayne
weswayne
    Kohai
  • 363 posts
Posted Today, 10:22 AM
Is the evaporator fan running? Have you checked for ice buildup on the evaporator?
#4 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 993 posts
Posted Today, 11:52 AM
Ok, I see that now, thanks.   What about changing the one in the FF section located on the top of the fridge and with a very short wire and no room?  Ever done one of those?
Doc
#5 BryanS
BryanS
  • 1,607 posts
Posted Today, 12:00 PM
https://www.amazon.c...ASIN=B004EFK6LK
I can't really see where the sensor is and have never had an issue changing them on a GE. Maybe a connector like the one above can work. Thats sort of like the ones Whirlpool sends with their sensors. I've used the regular butt splices on a very small sensor on an LG. It was a pain, but it worked. Are you sure you don't have a defrost issue or something blocking the air? I recently worked on a friend's bottom mount GE that had a double freezer drawer. I've never seen this style, but it had a defrost issue that couldn't be seen from the panel. The return vents were actually under the bottom of the evaporator and they were blocked off with ice and the freezer was cooling fine. You could always remove you air tower to verify if you are getting air up to the top.
#6 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 993 posts
Posted Today, 12:53 PM
I checked the damper and it works.  When I removed it from the fridge it was closed and when it was out I couldn't feel any aire coming into the fridge even with the fan running and the damper removed.  Maybe it could be those return vents.  I hadn't thought about that but now you mention it I should have had air (even if the damper wasn't opening) when I had it removed.   Dah
Thanks for that tip
I never checked the evap because no frost and the freezer was working good.  I need to pull the cover off, I guess because it's kind of a pain to get to it.
Doc
Edited by electro_doc, Today, 12:54 PM.
#7 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 993 posts
Posted Today, 08:03 PM
OK with the new information and a better understanding of what is going on I went back and checked the thermistors again.  By the way if someone is reading this and wants to know how to check them  then this is for you.  The fridge was at 70 degrees and I checked it at J1-5  &  J1-1.  It read 5.4 (close enough).  The freezer evap thermistor was was 2.1 and the freezer was 0 degrees,  I thought that was weird.  It  was checked at J1-5 and J1-4.   The freezer thermistor was 37.5 and the freezer was 0 degrees which is about right.  I checked it at J1-5 and J1-3.  I didn't open it up to inspect the evap because I had no time.  Just thought I'd send this out there and see it you have any idea why the freezer evao thermistor would be indicating so high unless the freezer just had a defrost cycle but then the freezer thermistor wouldn't be indicating the freezer was at 0 degrees.  Any thoughts?
Doc
0 members, 1 guests, 0 anonymous users
