Replacement timer WH12X10338 for GE washer WDSR2080G2WW - what's the trick to making it fit?
No replies to this topic
#1 SaraP07
SaraP07
  • 1 posts
  • Flavorite Brew:iced tea
Posted Today, 06:08 PM
The replacement timer for my washer has a couple of small brackets moulded into the plastic that aren't on the original, in addition it has an attached metal plate on the side that goes up against the front control panel, also being the side that the control knob's shaft extends from. The timer, once installed didn't fit; the knob's shaft was way off center and the control panel couldn't close. I removed it and cut off the extra brackets and trimmed back the tabs that held on the metal plate. Success! Got it all back together but now the new knob WH01X10310 won't lock on. It appears that the spot on the shaft that the clip needs to secure is too far under the level of the face of the panel! Why did they add the plate to these replacement parts and can it be removed completely? Now that I've removed the tabs I can't send this timer back. What to do? Thanks.
8 user(s) are reading this topic
1 members, 7 guests, 0 anonymous users
