GE Monogram Ice Maker Model ZDIS15CFFS
Troubleshooting
17 replies to this topic
#1 Sandyman
Sandyman
  • 5 posts
  • Flavorite Brew:Guinness Extra Stout
Posted 12 May 2015 - 11:55 AM
Turn machine on and nothing happens. After about 15 seconds cleaning light flashes once every second continuos. Unit is gravity drained.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,946 posts
  • Flavorite Brew:Killians Red
Posted 12 May 2015 - 12:51 PM
Check for loose connector on the bin thermistor...front right connector above cutter grid..if proper, check resistance on bin thermistor...can't remember the value at room temp...maybe someone else will chime in..
#3 weswayne
weswayne
    Senpai
  • Chief+ Appliantologist
  • PipPipPipPip
  • 733 posts
  • Flavorite Brew:Coke
Posted 12 May 2015 - 01:36 PM
Looking and the use and care manual, it reads "Every time the icemaker is turned off, you MUST clean the ice maker system with Nickel Safe Ice Machine Cleaner". Blah, blah blah...
Will it allow you to run a clean cycle? Make sure there is liquid in the reservoir and see if it will start the clean cycle.
#4 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 733 posts
Posted 12 May 2015 - 02:04 PM
mini manual 31-51316-1 for model number ZDIS15CFSS
Evaporator thermistor 18.7-69.5K Ohms
Bin Thermistor 25.9-29.8K Ohms
#5 Sandyman
Sandyman
  • 5 posts
Posted 13 May 2015 - 03:11 PM
When put into the cleaning mode nothing happens. I am leaning towards bad control board, assuming ice bin thermistor does not lock out that function as well. I will check out thermistor when I get back over that way.
The control board part number is Part number: WR55X10020
. They are proud of it.
#6 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 733 posts
Posted 13 May 2015 - 03:32 PM
From the mini-manual
The compressor runs at all times except when the bin thermistor resistance changes. This de-energizes the system except for the transformer, cutter grid and electronic control. Under normal operating conditions, when the evaporator reaches the preset temperature (+8.5 degrees to +4.5 degrees F, depending on thickness of ice) the evaporator thermistor signals the electronic control, terminating operation of the fan motor and pump. The hot gas solenoid and the water valve solenoid are energized at this time. Hot gas solenoid will remain on until the evaporator reaches 52 degrees F or until 16 minutes has passed. If the harvest cycle takes 16 minutes, the unit will go into failure mode and shut down.
#7 lvasquez11
lvasquez11
    Kohai
  • 279 posts
Posted 13 May 2015 - 09:38 PM
Whenever the unit has reached a failure mode, the LED will flash, and the unit will shut down. If the failure was caused during a harvest cycle which lasted more than 16 minutes, the LED will remain flashing on & off in half-second increments. If the failure is caused by a faulty bin thermistor, (not detected), the LED will remain flashing on & off in 1-second increments. These are the only two failures that cause the unit to reach a shutdown failure mode.
Unit will run without a evap thermistor.
check this kitchen aid iemaker model #  KUIA18NNJS4
#8 Maytag1
Maytag1
    Kohai
  • 373 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted 14 May 2015 - 07:20 AM
Bin thermistor Part number: WR55X10018
Edited by Samurai Appliance Repair Man, 14 May 2015 - 08:23 AM.
#9 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 733 posts
Posted 14 May 2015 - 08:55 AM
Is this information from a service manual? Something that would help me in the future.
#10 lvasquez11
lvasquez11
    Kohai
  • 279 posts
Posted 14 May 2015 - 12:14 PM
yes it is.  Job aid
#11 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 733 posts
Posted 14 May 2015 - 12:30 PM
got a link or a Job Aid number?
#12 lvasquez11
lvasquez11
    Kohai
  • 279 posts
Posted 14 May 2015 - 09:39 PM
KAR-14  on service matters
#13 Sandyman
Sandyman
  • 5 posts
Posted 20 May 2015 - 11:35 AM
Follow up. The bin thermistor and the evaporator thermistor both measured 7.2k ohms.
I replaced the control board and the unit came up and started running. Followed up today and the bin was full of ice.
Instead of using GE part # WR55X10020 I used Whirlpool part # 6100504 with a price of $186 vs $286.
#14 Patricio
Patricio
    Opa
  • 1,602 posts
  • Flavorite Brew:Home brewed ice tea
Posted 20 May 2015 - 12:05 PM
6100504 does not show up as a good part number on APP
Also wr55x10020 shows as a retail price of close to $400.  Even with my sizable discount that does not come to $286
Edited by Patricio, 20 May 2015 - 12:22 PM.
Former Student of Master Samurai Tech School.   Current Student of  Master Samurai Tech School
http://www.mastersam...iliate.php?id=5
#15 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 733 posts
Posted 20 May 2015 - 12:10 PM
How did you come up with a cross reference?
#16 Patricio
Patricio
    Opa
  • 1,602 posts
Posted 20 May 2015 - 12:23 PM
My next question is  Service Matters is for Whirlpool products I thought not GE products.  Am I mistaken
#17 Maytag1
Maytag1
    Kohai
  • 373 posts
Posted 20 May 2015 - 12:54 PM
Whirlpool built this ice machine Patricio
#18 lvasquez11
lvasquez11
    Kohai
  • 279 posts
Posted 21 May 2015 - 08:38 PM
U Member .   Whirlpool part # s are almost always found on part.
Nice job Sandyman
Also tagged with one or more of these keywords: Troubleshooting
