Whirlpool Quiet Partner ll DU1100XTPSA Soaking+Washing LEDs
6 replies to this topic
#1 archetype
archetype
  • 4 posts
Posted 16 May 2015 - 01:53 PM
My unit wasn't running and the Normal light was blinking so I replaced the front panel. The unit now runs. However, the Soaking and Washing lights are now on simultaneously during operation and the wash cycle never seems to end, or perhaps it just repeats itself. I canceled it after 2+ hours.
Any suggestions for what I should look at next?
#2 weswayne
weswayne
    Senpai
  • Chief+ Appliantologist
  • PipPipPipPip
  • 524 posts
  • Flavorite Brew:Coke
Posted 16 May 2015 - 03:52 PM
Try running the service diagnostics and monitor the process.
Tech sheet should be behind toe panel.
To enter service mode press:
Heated Dry, Normal, Heated Dry, Normal   (within 6 seconds)
#3 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,535 posts
  • Flavorite Brew:What's on tap?
Posted 17 May 2015 - 07:33 AM
Part number: W10134017
Check the thermister, machine will run forever if bad...
Edited by Chat_in_FL, 17 May 2015 - 07:33 AM.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#4 archetype
archetype
  • 4 posts
Posted 17 May 2015 - 03:52 PM
Thanks!
Here are the results of the diagnostic run:
Clean LED failed in intervals 16,15,14, and 2
Sanitized LED failed in interval 9
Drying LED failed in intervals 2 and 1
If I comprehend the diagnostic Notes correctly for Clean & Sanitized, the thermistor/soil sensor seems to be the cause. Would this indicate something else or additional?
#5 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 524 posts
Posted 17 May 2015 - 09:06 PM
Are the Soaking and Washing lights still on during operation and does the washer still continue to run on and on as stated in the original post? If so, go with what Chat posted.
#6 archetype
archetype
  • 4 posts
Posted 18 May 2015 - 09:15 AM
Yes to both questions. I'll replace the thermistor as suggested and report results.
#7 archetype
archetype
  • 4 posts
Posted Today, 01:40 PM
Update:
Replaced thermistor this weekend. No change in status. Soaking and Washing LEDs remain on simultaneously throughout operation and wash cycle never ends.
