wfw9150ww00 stops mid wash cycle with beeping and wash light flashing 8 times then 1 time
1 reply to this topic
#1 nemxwasp
nemxwasp
  • 1 posts
Posted Yesterday, 01:40 PM
wfw9150ww00 stops mid wash cycle with beeping and wash light flashing 8 times then 1 time. I read that the error is NO WATER DETECTED ENTERING WASHER OR PRESSURE SWITCH TRIP NOT DETECTED.
I removed any debris from the hot and cold water inlet valves as well as checked pressure switch hose for debris. I also blew into the pressure switch and heard the expected two clicks. I ran it on a cold cycle only with no errors (stopped it once it started to spin and drain). Ran it on a hot cycle only with no errors (stopped it once it started to spin and drain). It only stops and errors on warm cycle.
Not sure what the problem is since hot and cold alone work fine
Any help would be greatly appreciated!
#2 weswayne
weswayne
    Senpai
  • Chief+ Appliantologist
  • PipPipPipPip
  • 535 posts
  • Flavorite Brew:Coke
Posted Today, 03:51 AM
There is a laundry list of things to check out per the tech sheet.
Were you able to do the resistance checks as stated on the tech sheet?
