Samsung WF218ANW/XAA drain problem
1 reply to this topic
#1 bryankk
bryankk
  • 3 posts
Posted Yesterday, 02:37 PM
I have the above mentioned machine and it will get to the spin cycle and give the nd code. It seems to drain fine in the early cycles but not in the spin. After the first time, I cleaned out the debris filter and got a small amount of gunk but no solids. Started the amchine again and it got to the spin cycle and nd again. Drained the tub via the drain tube. Put the machine in Quick Test Mode, verified water valve, motor and door lock worked. No response from the drain pump. Anything else I should check or does this confirm the pump?
1. Anything else I should check or does this confirm the pump?
2. Can I replace just the pump without replacing the whole assembly?
3. Do I have to completely take the front of the machine off to replace it?
Thanks for any help, it is greatly appreciated.
    Shōgun
  • Master Samurai Tech
  • 30,713 posts
Posted Yesterday, 04:16 PM
Assuming there's free flow from the tub to the pump intake? Can verify by pouring a cup of water in the empty drum with the gookus-catcher out and see if the water flows right out. If that's the case...
Then either the pump is failing (common on Samsung washers) or there's something blocking the discharge hose/90 degree elbow. Either way, the sure fix is to replace the pump assembly. Part number: AP4564724
