Kenmore washer
#1
Posted 13 May 2005 - 01:48 PM
I have a Kenmore washer Model #92581210. The machine runs for about 10 seconds and then shuts down for about two minutes. Went through all motor and starter checks that the manual calls for. All tests fall into specs. This is a two speed motor with a direct drive transmssion.
I even changed the motor with a known good one and it still is overloading he thermal switch. Does anyone have a suggestion on what to check next?
#2
Posted 13 May 2005 - 05:57 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 14 May 2005 - 01:45 AM
You could have bad timer contacts sending low voltage to motor. Or, if your modle has a separate speed control switch it may be sending power to multiple windings at the same time.
Nick.
#4
Posted 14 May 2005 - 04:20 AM
Big Thanks to Pegi and nickfixit, my quest to not call a pro can continue. The machine does have a separate speed switch which has already been replaced once (reason for having an extra motor). I did check the switch but just for dead spots. I think I'll start and see if it actually switchs. An ohm meter is the only way I have to check the capacitor.
Have been watching e-bay for an oscilloscope, but can't seem to part with $200. Will write later with what I find.
Thanks again.
#5
Posted 14 May 2005 - 04:22 AM
Thanks again.
#6
Posted 14 May 2005 - 05:25 AM
I like the Fluke meters, but there are other fine testers out there. It's nice to have one with a thermocouple to test temperatures.
If you can not find any problems with your machine...
1. try a new motor cap, they are cheap
2. try a new speed selector switch , not too expensive
3. Replace the wire harness and timer
Your problem is one of the hardest to nail down. You get a wire or contact that is good enough to read proper resistance, but will not pass proper current. It's very tough to find, and you might go mental in the process.
Nick
Been Mental Quite Often
#7
Posted 16 May 2005 - 04:24 PM
Thanks for all your help.
Gizmo1
