Whirlpool WTW6200VW0 - Tub Bearing Smoothness
6 replies to this topic
#1 SpeedyG15
SpeedyG15
  • 8 posts
Posted Today, 02:47 PM
After removing rotor and stator, I am left with the tub, bearing, and shaft. When I turn the shaft, it doesn't glide effortlessly. There is a bit of resistance. Is this normal?
Background: I disassembled my laundry washer because I was hearing a roar when the basket spins at high speed. I looked for answers on the internet and found that the cause could be a leak in the seal of the tub that is destroying the bearing. Before ordering parts, I wanted to investigate as much as I could to be certain that a new tub would fix the issue.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,955 posts
  • Flavorite Brew:Killians Red
Posted Today, 03:30 PM
Very common failure...also, based upon our ratchet/socket conversation yesterday, a repair that exceeds your knowledge and skill level..expect to pay between 3-400 bucks for a pro to do this...you will need the bearing kit as well as a specialized tool set to do this job..
#3 SpeedyG15
SpeedyG15
  • 8 posts
Posted Today, 03:47 PM
I saw a video on replacing the bearing itself and it looks complicated. However, I think I could replace the entire tube if the bearing comes factory installed.
#4 Thirstytech
Thirstytech
    Senpai
  • PipPipPipPip
  • 548 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted Today, 04:17 PM
Here's what the kit looks like:
Part number: AP5325033
You'll need one of these, too:
Part number: AP5325072
Nearly every house in the USA has at least 4 major appliances that will need repair, learn how this can work to your advantage -> http://www.mastersam...iliate.php?id=6
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,955 posts
Posted Today, 04:23 PM
I've done both..the bearing is much easier than the whole tub.
#6 Thirstytech
Thirstytech
    Senpai
  • PipPipPipPip
  • 548 posts
Posted Today, 04:28 PM
Nothing but the truth right there!
#7 SpeedyG15
SpeedyG15
  • 8 posts
Posted Today, 05:04 PM
Is replacing just the bearing easier because it requires less advanced techniques and knowledge to perform it or because it takes less time? Or both?
4 user(s) are reading this topic
1 members, 3 guests, 0 anonymous users
