too hot Kenmore dryer
  • This topic is locked This topic is locked
4 replies to this topic
#1 Guest_rhallfidalgo_*
  • Lurking at the Threshold
Posted 14 May 2005 - 06:32 AM
My Kenmore dryer 110.86984110 runs too hot, even on the low setting. Samurai has helped me by telling me to replace the cycling thermostat. Where is this located? Is there a Whirlpool part that will work? Thanks.
  • 24,225 posts
Posted 14 May 2005 - 07:07 AM
Ah, the Whirlpool-built  27" dryer.  The cycling thermostat is mounted on the blower housing and has a bias heater (items 42 and 28)-- this page will help you with disassembly.  The bias heater may have opened in which case the thermostat will always call for heat. You should measure the resistance of the bias heater.
For the cycling thermostat CLICK HERE.
For the bias heater CLICK HERE.
#3 Pegi
Pegi
  • 13,120 posts
Posted 14 May 2005 - 07:42 AM
Your dryer will get too hot, so hot you cannot touch the top, if the air from the dryer is blocked from the dryer to the outside also.  Check your vent hose behind the dryer and from there to the outside.  If in doubt, pull the dryer out, remove the vent hose from the dryer and run it to see if the top is cooler.  And you could also have a grounded element causing it to by-pass all of the safeties in the dryer and never shutting off till you turn the timer to the off position.  If all of these check ok, see what temperature the dryer is cycling off at by putting a thermometer into the dryer vent while it is running on high heat.  It should cycle off at around 150*.  If it keeps climbing to say 170* you have a bad cycling thermostat or the element is grounded.
#4 Guest_Darren McCoy_*
Posted 28 December 2005 - 12:36 AM
My old early 1970s Whirlpool dryer heats up to higher-than-normal temperatures, and nearly caught fire a  few days ago.  Even on "AIR FLUFF" the heating element will heat up, to the point that I can't touch the dryer cabinet.
#5 Pegi
Pegi
  • 13,120 posts
Posted 28 December 2005 - 05:22 AM
Darren, check to see if the heating element has grounded itself to the canister, this will cause the element to stay on at all times unless the timer is off or the dyer is unplugged...
