Whirlpool frontloading washer won't spin
4 replies to this topic
#1 gwalchmai
gwalchmai
  • 4 posts
Posted 14 May 2005 - 08:15 AM
Hello. I'm a new guy with a problem.
I have a Whirlpool GHW9200LW Duet front loading washer, which has been great until yesterday (well over a year). It was in the middle of a normal wash cycle when the house lost power for a few minutes (not unusual). Now, the washer won't spin the drum. It emits a hum as though it's trying to spin, but nothing happens. Eventually a "02 F" display appears and the washer beeps slowly. The drum will freely rotate by hand. There is about 2 inches of water in the bottom of the drum which won't drain out.
Any suggestions would be appreciated. ;)
  • 24,218 posts
Posted 14 May 2005 - 09:44 AM
F/02
[align=left]Long Drain[/align]
[align=left]If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is[/align]
[align=left]flashed.[/align]
[align=left]Press PAUSE/CANCEL
twice to clear the display.[/align]
[align=left]NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later[/align]
[align=left]the F/02 error code will be displayed.[/align]
[align=left]Potential Causes[/align]
[align=left]•
Check the drain hose and make sure it is not plugged or kinked[/align]
[align=left]• Check the electrical connections at the pump and make sure the pump is[/align]
[align=left]running.[/align]
[align=left]• Check the drain pump filter for foreign objects[/align]
[align=left]• If the above does not correct the problem replace the pump[/align]
#3 gwalchmai
gwalchmai
  • 4 posts
Posted 14 May 2005 - 10:41 AM
Thanks SARM (EGMoA). Tried those. Looks like a pump. As far as I can tell the pump's not coming on at all I'm a software guy, so pump replacement is above my pay grade. Know any good repair guys in the north Atlanta area?
btw, this is an excellent resource. I work at a consuling engineering firm and we've been interested in this type of online consulting. If we could find a way to wring the money out of it... ;)
  • 24,218 posts
Posted 14 May 2005 - 02:53 PM
[user=727]gwalchmai[/user] wrote:
... so pump replacement is above my pay grade.
Ok, but you'd be throwing money away. Replacing the pump on this washer is about a mug and half on the SUDS-o-meter.
#5 gwalchmai
gwalchmai
  • 4 posts
Posted 14 May 2005 - 04:32 PM
Really easy? It's not that I'm without mechanical skills (I just detail stripped my 1911), but I've never taken that 200 pound beast apart.
