Kelvinator AW300G not draining
4 replies to this topic
#1 one_redraider
one_redraider
    Ikkō-ikki
  • 39 posts
Posted 25 July 2015 - 01:32 PM
Wash machine finished wash cycle but will not drain.  Any recommendations on where to start for reset or repair?
#2 weswayne
weswayne
    Senpai
  • Chief+ Appliantologist
  • PipPipPipPip
  • 831 posts
  • Flavorite Brew:Coke
Posted 25 July 2015 - 06:55 PM
Is the timer stalled out and not advancing?
Can you manually rotate the timer to drain?
#3 one_redraider
one_redraider
    Ikkō-ikki
  • 39 posts
Posted 26 July 2015 - 02:46 PM
I've tried a couple of different things 1. I've rotated the timer back around to the wash cycle and restarted . . . after getting to the end of the wash cycle, the unit stops then nothing happens. 2 Left the timer pulled out (in the on position) slowly advanced the timer through the remaining cycles . . .the only thing that happens is when the spin cycle is reached the unit agitator starts but after a period of time the unit stops and of course no draining occurs.
    Shōgun
  • Master Samurai Tech
  • 31,150 posts
Posted 27 July 2015 - 10:28 AM
Does the lid lock?  If not, it won't spin or drain Part number: AP2108159
#5 one_redraider
one_redraider
    Ikkō-ikki
  • 39 posts
Posted Yesterday, 09:35 PM
Thanks, I'll replace the part and see ……..
