Samsung ice maker
4 replies to this topic
#1 tharo
tharo
  • 3 posts
Posted Yesterday, 08:50 PM
I'm working on a Samsung refrigerator (RSG307AA) that is not making ice.
Ice maker sensor checked at about 4 volts (-12 deg F) this matched the display temp and infrared thermometer reading. So thermistor seems fine.
The Ice maker will start to harvest after bypassing fz door light switch with magnet, pressing i/m button for 10 sec and waiting for about 5 min. till it finally decides to harvest.
When the i/m did stop trying to harvest there no water and did not hear the valve activate. the i/m maker must have spun around 5 times before finally stopping. But again no water.
I jumpered neutral to the i/m water valve at the main board and it fed water to the Ice maker. So water valve does work and the water line is not frozen.
I have replaced both the i/m and the main board and it still does the same thing, the ice maker will harvest but will not activate the water valve at the end of the cycle.
Also the customer said it stopped making ice after changing water filter at first, but then after customer said it may not have been making ice before changing filter so not sure...
I'm at my wits end with this thing and at this point my only recourse seems to re-diagnose, maybe I got a defective board or ice maker.
But I guess my question is how does the i/m system signal the board to put N to the water valve? is it all started by a timer on the board that checks the i/m thermistor, and Ice bucket level then runs a  program cycle that includes activation of the water valve or is there an actual signal sent by the ice maker to call for water?
Any insight into this matter would be greatly appreciated.
Aaron
    Shōgun
  • Master Samurai Tech
  • 31,150 posts
Posted Today, 08:17 AM
Were you checking the thermistor on the icemaker it's self or the ice room? If you haven't checked the ice room for thermistor, you should check that one also.
And another thing: why is it so damn cold in there?
#3 Applianceman97
Applianceman97
    "Hollywood"
  • 2,798 posts
Posted Today, 10:05 AM
When the ice bucket is empty the freezer temp automatically drops to -14 to help the ice room get to temp. I'm assuming since it has not made ice for an extended period of time (days) that the freezer is constantly running at -14. That would explain the -12 in the ice room.
#4 tharo
tharo
  • 3 posts
Posted Today, 10:09 AM
 This is a side by side with i/m on fz door, so this is not the french door type with the ice room in the ff section.
But I am going back to re-diagnose it and will be checking all fz thermistors.
 From what I read until the ice bucket is satisfied (and ice is turned on) the refrigerator will bring the temp down to about -14 deg F. Once the ice bucket is full it will resume the actual set fz temp.
example: If customer does not have water hooked up to the refrigerator and the ice is set to on, it can cause problems with the fz being too cold, ice build up and inefficient because the ice bucket is never satisfied so its always trying to be -14 deg F to make ice.
    Shōgun
  • 31,150 posts
Posted Today, 11:06 AM
Dayyam, I knew that... Once upon a time. Must've blown away those brain cells many beers ago. Domo for the reminder, mah bruvah!
2 user(s) are reading this topic
2 members, 0 guests, 0 anonymous users
