GE Fridge PFSS5NJWSS not cooling, Already repl inverter/main brd
4 replies to this topic
#1 SteveinPas
SteveinPas
  • 1 posts
  • Flavorite Brew:chai tea
Posted Yesterday, 02:07 AM
Hi -
We have a GE Fridge that's about 8 years old. Model #PFSS5NJWSS. It's not cooling in the top nor bottom. I searched this forum and ran thru the tests mentioned. Here's what I did:
1. Checked compressor pins. 10ohms measured between any two pins.
2. Inverter is getting 120v as input voltage.
3. Here's where it gets weird: When I measure the voltage at J15 on the motherboard, it jumps around very rapidly. It is between 4-6 volts, but it can go from 4.3 to 5.7 and random places in between several times in one second.
I swapped out the inverter, but still no cooling. Same voltage weirdness at J15. I have also swapped out the main board and the replacement board is giving me the same voltage weirdness at J15. (Could I have gotten a bad replacement?)
Thanks for any assistance you can provide.
- Steve
#2 rbmappltech
rbmappltech
  • 17 posts
  • Flavorite Brew:goat milk raw
Posted Yesterday, 04:54 AM
Check the compressor amp draw.
It should be drawing .8 amps to 1.2 amps somewhere in that range its possible you might have a bad compressor or a sealed system leak.
#3 TheApplianceTechnician
    Kohai
  • 336 posts
  • Flavorite Brew:Bud light
Posted Yesterday, 07:51 AM
Where did you get your parts from?
Is the compressor trying to start?
Edited by TheApplianceTechnician, Yesterday, 08:05 AM.
“A man is most accurately judged by how he treats those who are not in a position either to retaliate or to reciprocate.”
www.theappliancetechnician.net
#4 weswayne
weswayne
    Senpai
  • Chief+ Appliantologist
  • PipPipPipPip
  • 833 posts
  • Flavorite Brew:Coke
Posted Yesterday, 09:22 AM
Have you checked any of the thermistors?
4-6vdc is what you are suppose to get.
#5 lvasquez11
lvasquez11
    Kohai
  • 292 posts
Posted Yesterday, 11:31 PM
Did you ohm out compressor pins. Are all other fan motors running
