Kenmore Dryer Series 80 No Heat
2 replies to this topic
#1 jdogchitown
jdogchitown
  • 1 posts
Posted 14 May 2005 - 12:47 PM
Hello
I have a Kenmore Series 80 Model # 110.77832795.  The dryer runs but there is no heat.  My question is where do I start my trouble shooting first.  2nd question is How do I access the Burner Assembly?  I have removed the back panel off the dryer.  I cannot figure out how to watch the burner assembley to see if it glows.
  • 24,677 posts
Posted 14 May 2005 - 02:50 PM
Start with the help on this page.
The entire burner assembly is accessed by removing the front panel, disassembly help here.
But you can watch the burner, without removing the front panel, through the inspection port on the front panel, below the door, to the left.
#3 Pegi
Pegi
  • 13,120 posts
Posted 14 May 2005 - 08:09 PM
If it is not heating at all, first check the ignitor mounted on the left side of the gas assy, it could be broken.
