WTW6200VW0 whirlpool washer bearing stuck
2 replies to this topic
#1 LisaStrickland
LisaStrickland
  • 2 posts
  • Flavorite Brew:Dunkin toasted almond
Posted Yesterday, 12:44 PM
I have taken this apart following the manufactures directions. Problem is I can not get the bottom bearing out. It broke into pieces, and the outer ring of the bearing is stuck. Nothing is getting it out. It almost seems like the betting is part of the metal plate on on the outer tub. Any help on how to remove the bearing (I did not buy removal rod, nor do I have the money to)
#2 Maytag1
Maytag1
    Kohai
  • 404 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted Yesterday, 11:18 PM
Use a Dremmle with a cut off wheel and cut a slit in bearing outer race. Then pry out. For those of you trying this repair in the future, don't just beat on one spot of the bearing. Go from 3 o'clock to 9 to 6 to 12. You get the idea. This greatly increases successful bearing removal. We do a lot of these, and having the bearing grenade sometimes happens to the best of us. Dremmel is a life saver with a high quality cut off wheel
#3 LisaStrickland
LisaStrickland
  • 2 posts
Posted Today, 11:52 AM
It doesn't come out. Even with a dremel. I can't seem to post a picture??
