UE error after changed bearings
6 replies to this topic
#1 Robertspinazzola
Robertspinazzola
  • 4 posts
  • Flavorite Brew:Nut Brown Ale
Posted 23 August 2015 - 03:26 PM
I changed the seal & Bearings on my LG Washing machine WM2442HW. It will no longer go past the 10 minute left point and will eventually reports an UE error before starting the spin cycle. I did double check the shock absorbers before I closed it up. I re-leveled the unit. Could you recommend some next troubleshooting steps?
#2 MicaBay
MicaBay
    Master Roaster
  • 1,115 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 23 August 2015 - 03:56 PM
Is the machine actually moving and shaking as if it's out of balanced?
#3 Robertspinazzola
Robertspinazzola
  • 4 posts
Posted 23 August 2015 - 04:07 PM
Not at all
#4 john63
john63
    Dean of LG Appliantology
  • 2,228 posts
Posted 23 August 2015 - 05:47 PM
When the tub bearings fail---it is not uncommon to find evidence that indicates water had leaked onto the BALL SENSOR---causing it to malfunction.
Part number: 6501FA2462E
Edited by Samurai Appliance Repair Man, 24 August 2015 - 07:51 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5 Robertspinazzola
Robertspinazzola
  • 4 posts
Posted 23 August 2015 - 08:34 PM
John
I assume you are recommending the remove and replacement of the ball sensor.
Are speaking from experience of fixing this? Could you describe where this part is located? Is there a way to verify the part is faulty?
Are there other parts that I should consider?
#6 Robertspinazzola
Robertspinazzola
  • 4 posts
Posted Yesterday, 10:17 AM
I replaced the ball sensor this AM. Unfortunately no change. Would anybody have other experiences with resolving this?
#7 Scottthewolf
Scottthewolf
    Senpai
  • 3,003 posts
Posted Today, 12:21 PM
It's a HALL sensor, not a ball sensor.
Scott Wolf
