Samsung Frontload Washer No Drain M# WF203ANS/XAC
samsung frontload washer no drain help
16 replies to this topic
#1 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
  • Flavorite Brew:Alexander Kieths
Posted 26 August 2015 - 04:31 PM
I got a call for a Samsung Frontload washer not draining today, I started it on spin only cycle and the door locks, then nothing, no humming no tub movement nothing. The only exception is I can hear a relay clicking twice (1 second between clicks) every 10 seconds. Pump motor is supposed to be 13.9 ohms and I read 14.5 ohms. With the door closed and cycle started I'm getting 0 VAC across line and neutral at the control but I'm getting 120 VAC with respect to ground on both the line neutral wires at the control. The door latch passed a continuity test and with the door open I get 8 VDC, closed I get 0 VDC. I'm not sure where to go from here. I'm not familiar with Samsung as a brand so any help is good help. Thanks.
#2 Applianceman97
Applianceman97
    "Hollywood"
  • 2,908 posts
Posted 26 August 2015 - 04:32 PM
120 VAC from Line to ground and Neutral to ground?
#3 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted 26 August 2015 - 04:34 PM
Yeah, both.
#4 Applianceman97
Applianceman97
    "Hollywood"
  • 2,908 posts
Posted 26 August 2015 - 04:37 PM
Do you have the fast track for this unit?
#5 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted 26 August 2015 - 04:47 PM
It won let me, says the file is too big. It's available in the downloads though.
#6 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Yesterday, 07:07 AM
Is there anything I can do to make it easier to get help?
    Shōgun
  • Master Samurai Tech
  • 31,379 posts
Posted Yesterday, 07:11 AM
I don't know what this means. Are you getting an error message? If so, what is it? Is the error message from your network, device, or from the site? Screenshot?
#8 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Yesterday, 07:21 AM
Yeah I tried to post the pdf file and it said the file was too large (over 500kb) on the site then I took a screen shot on my phone and it said the same thing.
    Shōgun
  • 31,379 posts
Posted Yesterday, 07:25 AM
Yes, 500 mb is too big. But why are you trying to POST the Fast Track? We already have that in the Downloads section. Applianceman was asking if you had the Fast Track for YOUR reference, not ours.
If you have the Fast Track, use that to troubleshoot. What's the first thing we do when troubleshooting an appliance with a computer control board?
#10 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Yesterday, 07:46 AM
Oh ok sorry guys I had a moment there. Yes I do have the fast track. Inputs and outputs right?
    Shōgun
  • 31,379 posts
Posted Yesterday, 08:02 AM
With a computer board, there's something you do even before you start poking around for inputs and outputs that's standard kata for any computer board. Look at the Fast Track and tell me what it is.
#12 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Yesterday, 08:13 AM
Ahh the all mighty service test?
I'm getting error #22 and "D" but the customer first said she got the error "ND"
#13 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Yesterday, 08:16 AM
The 22 error is what prompted me to check for proper door latch operation but based on the fast track info it seems to be within specs. Also on a side note what ohms reading would you consider to be too high resistance for the circuit if the norm is 13.9?
#14 Samurai Appliance Repair Man
    Shōgun
  • 31,379 posts
Posted Yesterday, 08:27 AM
Now go into manual service mode, turn on the water inlet valves to add water to the drum then activate the drain pump to see if the drum drains.
#15 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Yesterday, 09:29 AM
OK, I'm set to go there tomorrow afternoon. I'll give it a shot and update the results. Thanks, I really appreciate your help.
#16 Samurai Appliance Repair Man
    Shōgun
  • 31,379 posts
Posted Today, 05:40 AM
Let us know what you find.
#17 RiverviewAppliance
RiverviewAppliance
    Ikkō-ikki
  • 45 posts
Posted Today, 05:06 PM
I'm currently on site with the washer in service mode. The fill valves and motor are working however the drain and door latch buttons do not activate any response (no noise other than the jingle).
