Bravos dryer turning itself on and starting MGDX500XW0
1 reply to this topic
#1 Tone Blair
Tone Blair
    Kohai
  • 489 posts
  • Flavorite Brew:Coors Light
Posted Yesterday, 02:18 PM
Customer says the dryer starts by itself.
Is this an interface board problem, or the CCU problem?
#2 Thirstytech
Thirstytech
    Senpai
  • PipPipPipPip
  • 588 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted Today, 08:03 AM
I've seen this happen with the Duet dryers and the UI was the culprit. If it has a flat mylar ribbon cable (that connects it to the main control) check it for breaks or corrosion.
Nearly every house in the USA has at least 4 major appliances that will need repair, learn how this can work to your advantage -> http://www.mastersam...iliate.php?id=6
