Dryer heats with no drum - with drum; no heat
LG dryer
1 reply to this topic
#1 unusualagent
unusualagent
  • 1 posts
  • Flavorite Brew:Yeungling
Posted Today, 02:56 PM
Hello,
I have an LG DLE7177rm dryer that doesn't heat. I'm not making this up, but - if I take the drum and belt out and run it by pulling up the pulley on the motor, the heater works. When I put the drum back in, the heater doesn't work. This has happened three times. All of the old components tested out, but I've since replace the pcb board, the heater and the thermistor (even though they all tested out okay - I thought maybe it was an intermittent issue...)  So with all of those parts new (and the thermostats are on the new heater, so they're new too) - i without the drum, the heater turns on... I get excited, put the drum in and put it all back together - then the heater doesn't work (on any setting). There are no loose wires and as I said, it's happened three times.
#2 LI-NY Tech
LI-NY Tech
    We Fix Shit Great!
  • 1,078 posts
  • Flavorite Brew:Six Point Brewey Hi-Res IPA
Posted Today, 06:41 PM
Maybe a bad centrifugal switch on the motor which only manifests when there is tension on the motor pulley...
David
RD Appliance Service, Corp.
PO Box 234, Bethpage, NY, 11714
516-561-0523
http://www.rdapplianceservice.com
5 user(s) are reading this topic
3 members, 2 guests, 0 anonymous users
