Old whirlpool dryer -- when to remove life support?
#1
Posted 15 May 2005 - 09:18 AM
... which turned to amazement when, armed with superior web knowledge, my youthful assistant and I diagnosed the problem as a broken heating element and replaced the element at a fraction of the cost of a new machine.
Several months later, trouble again. The drum turned a couple of times and then slowed to a halt. We removed the belt and pulley, but the now unburdened motor exhibited the same symptoms. My interpretation of web scripture suggested to me that the motor might be bad, so we detached the motor from the fan (made possible only through the excellent picture on your site "Removing the Motor on a Whirlpool/Kenmore Dryer"). [Does the completely free motor turn and die? Can't tell. The motor now doesn't work at all, not surprising considering how hard I was whacking it]. The next step was to order a replacement motor. I found a drive motor (part 2584) that looked plausible. But at $97.80 for a dryer that was of indeterminate age when we got it in 1996,... well, the higher powers started casting thunderbolts -- ads for used dryers in the double digits -- and indicating doubt that I'd get the machine working even with a new motor.
So here is my question: When does it become right to cease one's striving and accept death as a natural part of the circle of life?
#2
Posted 15 May 2005 - 11:07 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 15 May 2005 - 11:28 AM
#4
Guest_Washer User_*
Posted 15 May 2005 - 07:25 PM
#5
Posted 19 June 2005 - 05:55 AM
My youthful assistant and I attached the wires to the motor, and with the excellent diagrams that came with the motor, we were reasonably sure that we did it correctly. Except for two points:
1. It was necessary (per instructions) to replace the 1/4” terminal on the 5M wire from the main harness with a 1/8” terminal supplied with the motor. It came encased in plastic. Puzzled by this, we chose to remove the plastic. I now think this was a mistake (for reasons that will become apparent).
2. The instructions directed us to reconnect the ground wire. The diagram showed clearly where the ground wire should come from and where it should go. The dryer showed clearly that it didn’t have a ground wire. The harness had only four wires: blue (4M), striped (1M), red (2M), and beige (5M). All were accounted for in the instructions.
Before reassembling the dryer, we decided to turn it on to see if the motor now worked (the old one under similar circumstances turned for a while then stopped). We put the plug back in the wall, turned on the dryer. Nothing. We made sure the dryer door was closed. Still nothing.
Got a voltmeter and checked the outlet. Normal. I was going to proceed from the outlet to see where the problem was, but I thought, Why not start at the end and work backwards? So I decided to attack the motor with the voltmeter... I paused for a moment, realizing that I had no idea what any of the wires and leads meant. Well, I thought, can’t do any harm, so I plowed ahead.
A minor explosion disabused me of my opinion. Closer inspection (after unplugging the machine) showed that the beige (5M) lead was now blackened, as was one of my voltmeter leads. No doubt I inadvertently touched both the beige lead and the adjacent striped (1M) lead. I now know the benefit of plastic casing.
But I don’t know why the motor doesn’t run. There was little room for error in following the instructions. I also don’t know if in causing the short I killed something: e.g., the beige wire, the red wire, the motor (luckily not myself). The voltmeter still works, for what little solace that gives.
I hope you can see something obvious.
#6
Posted 19 June 2005 - 09:50 AM
#7
Posted 19 June 2005 - 11:46 AM
#8
Posted 19 June 2005 - 12:00 PM
#9
Posted 25 June 2005 - 02:48 PM
...Did some piece of the dryer get lost during the operation? Is the switch a separate piece? Is it part of the motor? Does it lie under the arm? How big is it? How does the switch communicate with the motor? I've looked in vain for a picture of a motor, idler arm, and a switch. Here's the best I found: http://groups.msn.co...hoto&PhotoID=77
Thanks.
#10
Posted 25 June 2005 - 03:30 PM
#11
Posted 26 June 2005 - 05:37 AM
If THAT's not the explanation, then do you have any suggestion as to how to proceed? To recap:
1. I replaced the motor.
2. There is definitely electricity going to the motor when I turn on the dryer (see adventure with volt meter previously described).
3. The motor definitely does not do anything.
4. I'm as certain as one relying totally on instructions (without the benefit of electrical knowledge) can be that the wiring is correct.
Thanks.
#12
Posted 30 June 2005 - 01:38 PM
I (and youthful assistant) went back over the wiring. There was no possibility of error regarding the 1/4" terminal, but there seemed to be a bit of interpretation in deciding where to put one of the 1/8" termini. We tried the next slot over,... and the motor worked! Another victory for the forces of good!
Thanks for your help!
All that remained was to put the thing back together. Everything seemed to go OK (except the belt might have been somewhat less tight than I remember it being before, but still tight). In particular, the idler pulley seemed OK. The motor moved smoothly by hand, as did the fan.
But plugging it in evoked a terrible racket, like the drum was rubbing metal against metal. It did go, however (before I shut it off!). I could not get any noise when I turned the drum slowly by hand. The noise seemed to be coming from the middle of the machine, not the back (I could be wrong). According to some web wisdom, I'm supposed to suspect the idler pulley, but it looks fine to me (having seen only one idler pulley in my lifetime). Or, I'm supposed to suspect the motor, but that's brand new! The rollers in back looked OK too (but again, I'm not sure what to look for).
So near... but still not a working dryer.
I am imagining (and hoping) that the problem is a defect in my reassembly technique. Suggestions on what I should look for?
#13
Posted 30 June 2005 - 04:32 PM
#14
Posted 01 July 2005 - 03:38 AM
Thanks.
#15
Posted 01 July 2005 - 07:24 AM
#16
Posted 02 July 2005 - 09:00 AM
So, until our next Whirlpool adventure, adios!
#17
Posted 02 July 2005 - 03:33 PM
