GE Dryer stops when releasing ON button
#1
Guest_Robin_*
Posted 15 May 2005 - 10:44 AM
Robin
#2
Guest_Robin_*
Posted 15 May 2005 - 10:46 AM
#3
Posted 15 May 2005 - 11:22 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#4
Posted 15 May 2005 - 11:56 AM
--Robin
#5
Posted 15 May 2005 - 05:29 PM
#6
Posted 16 May 2005 - 05:15 AM
We're awaiting the part, and borrowing our neighbor's dryer in the meantime.
--Robin
#7
Posted 16 May 2005 - 05:35 AM
#8
Posted 18 May 2005 - 07:08 AM
--Robin
#9
Posted 18 May 2005 - 07:46 AM
#10
Posted 18 May 2005 - 11:04 AM
"To restring the belt on this sorry excuse for a dryer, remove the phillips screw inside the rear exit opening of the blower duct and remove the duct. Then restring the belt from the front. "
Why do we need to remove the duct?
With our next appliance, I'm going to consult these pages to find out what's easiest to fix!
--Robin
#11
Posted 18 May 2005 - 11:36 AM
#12
Posted 19 May 2005 - 12:24 AM
If you have an access panel on the back then use it, otherwise you will have to string the belt by feel, (kind of blind like), working from the front with the vent tube out you will be able to reach through front and see what your doing.
Eureka, CA 95501
#13
Posted 19 May 2005 - 03:38 AM
Well, I do have another question before we try putting this all back together. I understand how the dryer is routed, but I don't understand the following instructions:
You took the quote out of context. Read the entire paragraph from which it was taken and the reason for removing the vent, on some variations of this dryer, is perfectly clear:
Variation 1 has a rear access panel through which you can restring the belt. Variation 2, however, does not have this rear access panel. (Thank you, GE
) To restring the belt on this sorry excuse for a dryer, remove the phillips screw inside the rear exit opening of the blower duct and remove the duct. Then restring the belt from the front.
#14
Posted 19 May 2005 - 07:35 AM
There's a funny sound, and I think it's coming from the front. I recall a little tab on the front panel that looked loose, or not secured or something. I'm guessing that's it - so we need to disassemble a little and fix it. I'm hoping that's it, because if it's not, I have no idea what the sound is.
So stringing other brands is easier? That was a pain.
--Robin
#15
Posted 19 May 2005 - 08:11 AM
#16
Guest_meadowsweet3@yahoo.com_*
Posted 31 January 2006 - 05:27 PM
