No water or ice from dispenser
2 replies to this topic
#1 Guest_Dan_*
Guest_Dan_*
  • Lurking at the Threshold
Posted 17 May 2005 - 07:27 AM
Domo & conichiwa Samuraison.........My GE side by side water and ice cube dispenser stopped working. The flap for ice still opens but thats it. Dispenser switch works. Was purchased in July of 03.  Any suggestions would be appriceated.
Thanks.......Dan      :( :?
#2 Pegi
Pegi
  • 13,120 posts
Posted 17 May 2005 - 10:21 AM
Will need a model and serial number to be really able to help you, but let me see if we understand this.  You get no water thru the water dispenser and no ice thru the ice dispenser.  This could be one problem with the board itself or two different things, like the fill valve went bad on the water disp side but the augar motor is not running on the ice disp side.  Please give more details on what exactly the problems are....
#3 FatMan
FatMan
    Sōhei
  • Master Appliantologist
  • 233 posts
Posted 17 May 2005 - 10:22 AM
And the model # is..........:bathead:
