GE fridge TFX26PPDACC blows fuse when opened
#1
Guest_Peter_*
Posted 17 May 2005 - 10:28 AM
I plugged it in to check it out once we got it home and as soon as I opened the door, the fuse in the basement blew. I flipped the breaker back, and opened the door a second time just to make sure it wasn't a fluke, and a different fuse blew. Is this a problem with my fridge, or with the wiring in the house?
If it helps, when transferring the fridge home, it was laid on its side, with the freezer side down.
#2
Posted 17 May 2005 - 11:11 AM
#3
#4
Guest_Peter_*
Posted 17 May 2005 - 07:10 PM
The freezer started emitting a white haze that smelled like burned rubber or something. Could this be oil in the line from having it on its side? I read somewhere that that is one of the things that could happen. Will letting it sit for a while help with that, or does it need to be flushed out?
Thanks for the input so far. I will check out the short circuit situation next time I am over there.
#5
Guest_Fridge User_*
Posted 18 May 2005 - 10:02 AM
.... and a different fuse blew.
Sound strange blowing "two" different fuses for "one" problemaic fridge!? :?:?
#6
Guest_Peter_*
Posted 18 May 2005 - 10:56 AM
#7
Posted 20 May 2005 - 03:00 AM
Honestly, the expense of repairing it isn't worth it, the white haze that smells like rubber burning is a good sign of a burnt out compressor.
#8
Guest_Peter_*
Posted 01 June 2005 - 10:05 AM
#9
Posted 01 June 2005 - 11:39 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
