      5
      All Appliantology tech members are invited to join in this workshop on all things Appliantological.
      We have a special session planned for this one. Instead of the usual Show 'n Tell on a technical topic, we're going to post tech sheets in the comments to this Calendar Event (scroll down to see what's posted so far) and ask specific questions that can only be answered by reading the tech sheet. If you at least try to answer the questions beforehand, you'll get a lot more out of it. The tech sheet and the questions are posted in the comments section below.
      Your mission, if you should choose to accept it, is to check out the questions for each one and try to answer them ahead of time. Then come to the Dojo to see how well you did!
How To Fix A Range Or Oven That Won’t Start?
Marlon Thomas
  • Hiroshi
  • leamy
  • Thirstytech
  • Marlon Thomas
HMMMM... don't eat yellow snow..
in order to help a model number, brand and an accurate description of your problem is the first step.
The best way to fix your problem is to hire a local tech to fix it, all you have to do is write a check to get it done
todays appliances are hard to fix even for the educated.....
Link to comment
Advice: Gas ovens are more approachable DIY projects than electric ovens... You only get one mistake with 240V on a 50 amp breaker!  :excl:
Link to comment
Hmm....a range or an oven that wont start? I don't like to generalize but usually it's...........:no:
Link to comment
