kitchen stove
7 replies to this topic
#1 Guest_whiteice_*
Guest_whiteice_*
  • Lurking at the Threshold
Posted 17 May 2005 - 06:02 PM
hey   i have a new stove bought last year it stainless steel and it doesnt seem to want to work   the elements wont go on.   i checked the fuses in the stove and there all good   and i checked the main fuse box and  that fuse was okay to.   the clock on the stove works when the element is turned to the on position but soon as i turn it to the off position it goes off.  could it be the plug in or the wiring it self
whiteice
#2 Pegi
Pegi
  • 13,120 posts
Posted 18 May 2005 - 12:13 PM
Brand, model and serial numbers...........
#3 nickfixit
nickfixit
  • 1,965 posts
Posted 18 May 2005 - 12:33 PM
Are you saying the surface units do not work AND the bake and broil do not work?
Is it gas or electric?
If it's electric, you probably have a power supply problem or a wire burned off between the breaker and the stoves terminal block.
Nick
#4 Guest_whiteice_*
Guest_whiteice_*
Posted 19 May 2005 - 06:25 PM
its a maytag stove   and yes none of the top burners or the oven doesnt work.   if its a wire burnt out  do you have to change the hole wire going from fuse box to stove block.
  • 24,321 posts
Posted 20 May 2005 - 03:05 AM
Measure the supply voltage at your range outlet.  The photos on this page will show you what to measure and where.  This page will teach you how to measure.
#6 Pegi
Pegi
  • 13,120 posts
Posted 20 May 2005 - 11:14 AM
This page will ask for the Model and Serial numbers again...............:bathead:
  • 24,321 posts
Posted 20 May 2005 - 11:21 AM
Hey, I thought *I* was the cranky one around here!  :laughing:
#8 Pegi
Pegi
  • 13,120 posts
Posted 20 May 2005 - 11:31 AM
Well, you are not the only one allowed to have all of the fun in here, are you???  :silly:
