Maytag oven door HELP!!
1 reply to this topic
#1 Guest_Tabitha_*
Guest_Tabitha_*
  • Lurking at the Threshold
Posted 17 May 2005 - 06:18 PM
Maytag Flat top Stove Model # PER5750QAW SERIAL # 12656647CR
Someone left the oven door drop to the floor now the hinge is completely off the stove. The hinge is still connected on one side but the other side is not connect to the stove. What do I need to do? I tried to get it back on but no such luck.
  • 24,321 posts
Posted 18 May 2005 - 02:29 PM
Pull the door completely off the range. Cock the hinges so they stick out from the range at a 45 degree angle. Slide the door back down on the hinges. Unless something was broken or bent, this is easy as bip-bap-boom.
