  • Announcements
Guest HousewifeUnderLaundry
Dryer pops breaker
10 posts in this topic
I live in a moble home and my dryer keeps poping my breaker. Had breaker checked, fine. It is a Norge super large capacity and this only happens when I try to dry a full load. I can dry one or two items with out a problem but anything more and 'snap'. I checked the plug in back, it seems to be attached right and I don't feel any heat. Any ideas? Could sure use your help, my laundry is piling up fast!
I was afraid of this. No one knows how to help, huh? Is it because it is a Norge? Could it be a censor of some kind? It only seems to snap with a full load of wet clothes.
Would help if you would post a model number, or at least if it was gas or electric???  And give the techs that are busy and out working, not sitting here waiting for someone to post on the board, time to see your question.  Pegi
More clothing = more weight = the motor has to work harder and therefor draw more amps. Being a mobile home I don't think that particular washer was meant for the wiring. If there were a short it'd blow a fuse in the washer and then the washer wouldn't work.
If course the plug won't be hot; it was designed to handle the full amperage load of the machine and if it shorted, then the power would be disconnected internally.
A good idea is to check the wattage output of each circut. If it doesn't say, then measure the wire, get the gauge off of it and check for the max voltamps output on the wire.
Let's see, you post a question in this appliance repair help forum and you didn't get a reply in less than an hour? I see. Well, please accept my apologies for your inconvenience and for the obviously substandard service you have received here. This is totally unacceptable and you obviously deserve better than this. Please fill out this form and you'll receive a special gift for your trouble.
She said this was a dryer, not a washer............
Wow. I apperantly offended some people with out meaning too. I am sorry. This is my first time at this site and I didn't realize it might take a while to get an answer. For some reason I thought (since I could tell that people had been checking the question) that it was a 'manned' website with someone online answering questions in almost real time. That's what I get for thinking. Again, I'm very sorry.
Mum, we are listening to your model no.:P
No one can really help you without the model number, this dryer is probably made by Maytag, but we do not know.   Your breaker is popping either because the dryer is drawing high amps or you have something wrong with the electrical to the dryer.  I am "assuming" this is an electric dryer which would take two 30 amp breakers.  So either you have a bad breaker, or they are not 30 amps, or you have something wrong in the breaker box or to the wall outlet, or a burnt wall outlet.  If all of that is ok, you have something inside of your dryer that is causing it to draw way too many amps in the heat circut, like the element is grounded.   How long has the dryer been in this location?  Did this just start poping the breaker or was this dryer just installed at this location and has done this from day one.  Is this a new dryer or an older one???   There is a lot more  information we need here to help you but WE NEED MORE INFORMATION PLEASE.
Well,really it is because it's a Norge.No model number,but my guess is it's a problem with your electrical box.
Guest
This topic is now closed to further replies.
