Dreaded F7 on GE built in.
#1
Guest_Ishtim_*
Posted 18 May 2005 - 06:36 AM
http://fixitnow.com/...ge-built-in.htm
When I powered the system back up, the code immediately goes to F7. Can any one help me pinpoint the error, or am I out the keypad + ERC? :X:X:X
Thanks in advance!
#2
Posted 18 May 2005 - 02:26 PM
You need both the touch panel and the ERC.
#3
Guest_Ishtim_*
Posted 19 May 2005 - 03:06 AM
The error after the 24hr test is actually an F0. Do you know if there has been a re-engineering/re-design of either of these parts or can I expect a $300+ parts bill every few years?
FYI: This error began the day after our last self-clean cycle.
PS: Did I tell you that I make my own beer? HOw can I send you some? Current Batch (currently lagering) Marzen or Oktoberfest beer that was brewed in March.
#4
Posted 19 May 2005 - 04:11 AM
#5
Guest_Ishtim_*
Posted 23 May 2005 - 04:23 AM
Thanks for the advice!
I'll let you know how the installation goes...
#6
Guest_Rigi_*
Posted 03 June 2005 - 07:00 PM
The reason I ask is that I'm experiencing just that problem. On my GE Profile dual oven (Model JTP56WOW2WW) we started getting the intermittent F7 error. Did the pink eraser test with no improvement. Attempted the disconnect test but upon reapplying power I got an F0 error within 5 minutes. Very repeatable.
Is it possible that a problem with the ERC is causing the F7 error when connected to the keypad and the F0 error when disconnected? Or is that for some reason impossible?
Thanks for the advice oh knowledgable one.
#8
Guest_Kent_*
Posted 08 February 2006 - 11:28 AM
The funny thing is that the ovens still operates ok, especially when the unit has been sitting with the power off (at the breaker) and I don't operate it too hot.
Just last night I disconnected the ribbon cable, and got the F0 error right at 5 minutes. Does this mean I need a new ERC, or ERC+keypad? And why does the silly thing still operate with a bad ERC?
Thanks.
Kent
#9
Posted 08 February 2006 - 03:45 PM
It is nice when they error like that consistently so you can experiment and pinpoint the problem. Most of the time they error intermittently.
May the Force be with you and guide you through these darkest of times as you battle with this most evil machine manufactured by the Great satEn in the very depths of hell itself.
#11
Posted 09 February 2006 - 02:39 PM
#12
Posted 11 February 2006 - 07:23 AM
#13
Posted 11 February 2006 - 04:08 PM
#14
Posted 13 February 2006 - 01:59 AM
#15
Posted 13 February 2006 - 03:45 PM
#16
Posted 14 February 2006 - 12:25 PM
#17
Posted 14 February 2006 - 05:08 PM
#18
Guest_bumgarner78_*
Posted 22 February 2006 - 04:23 PM
First question is, is there anything I can try to reset the oven other than turning off the breaker which I have done?
Second question, this oven was installed 12/98, about 8 years ago. Whats the average life of a product such as this?
Any help or advice will be appreciatted!
Aaron
Bumgarner78@hotmail.com
#19
Posted 26 February 2006 - 04:54 AM
FO fault code started late summer 2005. I could clear it for a while (week or so), then had to pull the breaker. I replaced the control panel once. No fault codes for approximately 2 months or so (can't actually remember). Started up again. With repairclinic.com's great guarantee, I replaced the control panel again yesterday with yet another new one. FO and incessant beeping started within 10 minutes!!! Grrrrrr...
This morning, based on reading this site, I tried pulling (gently, of course) the ribbon cable. Upon return of power, beeping and FO were immediate, with ribbon cable disconnected.
After reading this thread, I'm a little confused (I'm a female with no repair experience at all, although the control panel was pretty straightforward with using lots of pre-disconnect close-up digital pictures to guide me through the re-connections!!!! :) )
Anyway, do I or do I NOT try replacing the touch pad part? Or should I just get a new freakin' oven (non-GE, of course!!!) I hate GE, I've always hated GE...too bad this beast came with the house!!!!
Thanks for any help!
Regards,
Michelle
#20
Posted 27 February 2006 - 04:43 AM
I have a newer (maybe 2002...)GE electric double wall oven (Kenmore, actually - made by GE).
Regards,
Michelle
Follow-up to above message: I cleaned the ribbon cable with a pencil eraser...NO beeps for almost 24 hours!!!! I hope it lasts, then I can send that $150 part back just as soon as it gets here! :)
This topic is locked
