water dispenser
2 replies to this topic
#1 captbob
captbob
  • 1 posts
Posted 18 May 2005 - 12:17 PM
how do you get the cover off the door to get at the spout for the water dispenser, which is broken. kenmore-whrilpool model number 106.57287791
  • 24,218 posts
Posted 18 May 2005 - 02:16 PM
Carefully pry the face off with a thin, stiff putty knife (item 21). That's the only non-obvious part, the rest is trivial.
#3 Budget Appliance Repair
  • 3,996 posts
Posted 19 May 2005 - 01:31 AM
Do as Samurai say, but don't pry from top. Pry bottom off first it has smaller plastic keepers keeping it in place than the top does, you will most likely break the retaining plastic tabs off if you pry from the top.
William Burk (Willie)
Eureka, CA 95501
