edcorsaro
GE washer giving me much grief
7 posts in this topic
Model WWSE5200B1WW. 2 yrs old. doesn't spin or aggitate. Sometimes it does, but most of the time the motor goes on off on off on off. I hear what I think is the centrifical switch on the motor going on off on off. I pulled the belt and the motor runs fine in aggitate. During spin it clicks on off on off. the more pressure I apply to the motor shaft the worst it gets. The pump works fine. Any suggestions?
If the supply voltage to the motor is steady, then you need to replace the motor.
Where can I get a wiring diagram, or can you tell me which is the hot wire? Thanks
The wiring diagram is inside the control console.  If you need help reading it, post it here or fax it to me, 775-416-4449.
Well, I think I stumbled on the problem. When I turned the cycle speed knob. (you know , the one that changes the spin and aggitate speed. i.e. Gentle, fast ect.) it started to work. I have done 5 loads with no problem. I guess this means I need to buy this switch. Is this true? I couldn't find it on your web site. Thanks. where do I send the beer?
You can get any part you need using the convenient form at the bottom of this page, scroll down.
Love offerings of beer go to the United Samurai Beer Fund.
Ed: Any update on this? My GE WPSE5290AOWW is having the exact same problem. I tried messing with the switch, and I can get it to work, but it is inconsistent. I can do a load w/ no problems, then the next load on the same setting starts clicking during spin.
I also believe it is the switch mechanism, but at $120...I'd like to be damn sure. Thanks.
