No air blowing...
Judoka
OK...I know very little about central air systems.
Symptom - I set thermostat to cool, fan to auto. I can hear the air intakes operating and the a/c unit (York) is operating outside the house....BUT, there is very little to no air circulating through the house.
Suggestions?
  • Replies 8
have you checked to see if the filter in the furnace unit is clean?  Is the blower fan coming on as well?
I have not checked the filter in the furnace...not even sure where to look for it....(the filter, that is). The furnace is in the attic, so I was planning to go up there and make sure that all the ventilating tubing is connected. I never have cleaned the furnace filter, so that sounds like it might be a stopping point for the air flow.
Not sure if there is only one fan or two. I thought there is only one blower, and it controls the air intake and circulation of air out as well. but not certain.
Will poke around to find filter and go from there. thks
Oh...another point. I have 2 air intake points (1 on first floor, and 1 on second floor). I put filters in those once every month or so....is there going to be another filter in the furnace as well?
The two intakes that you describe are the cold air return ducts.  This is where your
furnace gets its circulation air from.  There is no real need to install filters in the cold
air return because that is the job of the filter in the furnace.  Generally, the filter is
located inside the service panel either in the front or on the side of the cabinet, on
the intake side of the blower.  If you follow the cold air return duct as it connects to
the plenum and leads into the furnace, this is where your filter is located.  You may
have a model the you can clean and reuse or they might be disposable.  Pay
attention as to the way it is installed - there is usually a sign or arrow indicating air
flow direction.
Jonathan329
As it happens, I have the exact same problem (or, my mom does).
She cleans her filter pretty regularly. What else should I look for?
jonathan
Is the problem restricted air flow at the vent openings?  Make sure your filter is clean and the cold air return ducts are clear.  Also check the vents to see if there are any dampers that are closed - they should be open.  There may also be a possibilty that the evaporator in the furnace is plugged with dirt, but check the others first.  Depending on your model of furnace and thermostat when cooling is selected the blower should run on high speed.  There are blower motors that have variable speeds - if yours is running on low speed you will have less air flow.
their is also a possibilty that the ducting it self has pulled loose partially from the registers
Could be any number of things. Is the blower wheel dirty? Can you feel air circulating with fan switch set to "ON" and System switch set to "Off"? Does it circulate air at first with A/C on but stop after a while? The A/C coil could be freezing up due to low refrigerant levels or restrictions/bad metering device.
