SXS Kenmore won't dispense water
3 replies to this topic
#1 Carole
Carole
  • 11 posts
Posted 19 May 2005 - 09:04 AM
Good morning - I have a Kenmore Side-by-side that dispense ice but not water - model 596-57582790.  Any ideas as to the problem on this one.
Thanks a bunch
Carole
#2 Pegi
Pegi
  • 13,120 posts
Posted 19 May 2005 - 12:56 PM
You could have a defective fill valve, a frozen line or tank, or an electrical problem in the dispenser assy itself.  Or a wiring problem to the disp area to or in the door.  Would start with checking the water valves first.
  • 24,712 posts
Posted 20 May 2005 - 03:20 AM
Your water inlet valve will be a double, as shown here.  You'll need to use your multimeter to check the continuity of the water dispenser valve coil.
#4 Pegi
Pegi
  • 13,120 posts
Posted 21 May 2005 - 04:25 PM
The valve could go bad internally, not opening when power is applied to the coil.  Best to test this coil with at test cord direct to see if it opens and allows water thru it.
