Trying to reset hi limit on a Dacor oven
7 replies to this topic
#1 sandstones
sandstones
  • 2 posts
Posted 19 May 2005 - 03:16 PM
Getting all kinds of conflicting information on what to do with our 3 year old Dacor oven
Its a double oven - when broiling in the top oven my wife opened to check on what was cooking and apparently blew some sensor. Now the top open won't go above 135, even though convention fan comes on.
Talked to Dacor and have been told a different times that a) need to replace a part but because it is a frequent problem they would pay for parts if we had it installed by a Dacor authorized repair place, or b) that this is just resetting the high limit. When on solution A they wanted $150 to install the parts, which seemed out of line.
Is this reseting something I can do, and if so how? What, if anything, actually gets replaced?
SS
#2 Pegi
Pegi
  • 13,120 posts
Posted 19 May 2005 - 06:44 PM
Sorry I do not know this system, but someone who does will be sure to help you when they see your post....Pegi
  • 24,347 posts
Posted 20 May 2005 - 03:01 AM
There is a high limit thermostat behind the grill of the upper oven.  It opened because when your wife opened the door, she interrupted the oven cooling air circuit.  By the way, these don't blow when the door is just opened for a peek.  The door would have to have been held open for a couple minutes or more.
Fortunately, these thermostats are re-settable.  Cut power to the oven, remove the grill, reach in and press the button on the hi limit t'stat to reset it.
And no more cooking with the door open!
#4 sandstones
sandstones
  • 2 posts
Posted 22 May 2005 - 12:28 PM
And thats all it was - 10 minutes with a screwdriver for someone who had never opened up this over before.
And to think the Dacor recommended appliance guy was quoting between $100 and $200 to fix this.
#5 Pegi
Pegi
  • 13,120 posts
Posted 23 May 2005 - 09:15 AM
I  am sure he also thanks you, Samurai.    ......;)   I thank you......:cool:
#6 Mortimer Snerd
Mortimer Snerd
  • 1 posts
Posted 26 June 2005 - 02:37 PM
This sounds pretty much exactly like the problem we're having - and caused the same way.
Difference is that ours is a Dacor ERD30S064CH (30" dual-fuel with gas broiler).
I assume there's an equivalent thermostat reset for this model, but I can't find it!
Any clues?  Thanks very much.
Mort-
#7 ljw
ljw
  • 1 posts
Posted 06 August 2006 - 12:28 AM
soooo, I have the grill off (the stainless plate over the lock latch, right?) - but don't see a reset button. any hints? thanks
  • 24,347 posts
Posted 06 August 2006 - 12:36 AM
It's a little red button in the thermal hi-limit switch. Find the thermal hi-limit and you'll find the button. So, now you're wondering what the thermal hi-limit looks like. Get your model number, scroll t the bottom of the page and plug your info in on the parts lookup table. You'll get to a picture of it.
