anna777
kenmore washer help needed
16 posts in this topic
washer (11020924990) Kenmore appears to be washing fine. After spin the clothes are not as dry as they should be.  It spins but slower then usual and squeaks.  Im ready to replace the motor coupler, again, but is it necessary?  What is the problem?
PS how do I get the agitator off? I  removed lid now I see a small bolt (?) about 3 inches into the agitator. Do I need to remove bolt?
Cool, a model number!!   Thanks!!!   Yes, remove the bolt and the whole agitator will pull off.  The squeeking and slow spin could be several different problems, but I would suspect something between the spin basket and the tub first.  Or your drive block that spins the basket is wallowed out and has dropped down on the spin tube and the bottom of the spin basket or filter, if you have one, are scraping on the bottom of the tub.  You could have a clutch/break assy going bad but I have not heard them  squeek.   Pegi
Thanks for the suggestions Pegi!
What would do fiirst? remove agitatior or?
Remove the case, the top. sides and front come off one piece from the front after you flip the console over the back panel.  You might be able to see if something is between the tub and basket since the tub is fiberglass and you can see thru it. Remove the agitator, then the splash guard and spin basket and take a look.  You might be able to see if something has left a rub trail on the tub.  But that is a lot of work if this is not the problem.  See if you can remove the case and jumper the lid switch to turn it on in  spin and see where the squeek is coming from??
I remember it is simple but my simple mind cant remember how to remove the clips so I can remove cabinet. pry up or?
Pull 'em out and up using a long screwdriver.  This page has more help.
so far so good
cabinet is off. I dont see, or feel ( ran a stick around between drum and liner)
squeek is from center below agitator. is that a screw or a bolt down the center of the agitator? I didnt see any pictures that look like my machines agitator.  it is 2 pieces a large fin piece on the bottom and a seperate piece on topa about 5 inches long where the clips are
ok I got the agitator off.  I see a plastic washer that is broken and some metal "shavings" around. Nothing was tangled under agitator.
can inner tub be removed to clean and check outer tub?
Look at the big nut that holds tthe spin basket to the drive block. That drive block should be at the same height as the 2 raised edges of the spin tube. If it is lower, and you see metal grindings, you need a new drive block.
Nick
no it does not appear to be lower.
the motor coupling was ok.  im trying to remove the nut to take out the inner drum. slow going without a spanner tool. but I will do it
thanks for all the info
anna
:yikes:UPDATE: motor coupling is ok.  removed inner drum. Spanner nut was a devil to get off!   Block drive came right off with inner drum. to my inexperienced eyes it looks a bit worn. Noticed filter at bottom of inner tub seems worn, teeth missing, bottom of outer plastic tub scratched.
does any of this add up to my initial problem of a slow spin?
what parts should I replace?
anna
Do your inexperienced eyes see a perfectly round hole at the top of that drive block, (missing the two cut out notches that the top two tabs on the spin tube engage).
If this is what you see that, YES, you have a bad drive block. It has stripped out the tabs and top of the drive block that keeps the tub up to the correct level.
When the drive block goes out like this it lets the tub drop down and rubs the plastic filter against the buttom of the outer tub and stop the spin.
Here's where you can get a new one, (also see picture of good part to see what it should look like). CLICK HERE
Willie, when I look down the center of the drive block there are no tab cut outs and yes it looks worn compared to your picture of a new one.
should I replace the plastic filter too?
thanks,
anna
This would cause your slow spin and squeeking since the filter was scraping on the tub and the drive block just sliding on the spin tube.  You might as well replace your filter also if it is very damaged along with the drive block.
will do
Thanks to everyone for your help. Dont know what this old woman would have done without you all!
God bless,
anna:D
Thank you and you are quite welcome......:cool:
