Kenmore oven won't heat 362.7555190
#1
Posted 20 May 2005 - 05:50 PM
The oven will not heat up at all. I replaced the igniter I bought from Sears ($65.00) and it still doesn't work. It does not glow at all. I have read some of the other posts and one said to check the internal fuses. One problem is I cannot find and have no idea where the darn thing(s) are. I am dreading if it is the valve. There is no gas smell, no glow and I have left it on for an hour. Is it possible that I bought a faulty igniter from Sears? When I can find something to test the voltage, I will see if I can figure out how to use it.
Do you have any suggestions? I have three small panels off the back of the stove right now. I doubt it is the thermostat but I am open for suggestions.
Please help.
#2
Posted 20 May 2005 - 06:20 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 21 May 2005 - 04:04 PM
#4
Posted 22 May 2005 - 05:06 PM
When I turn the oven on, all I hear is the click of the "oven cycle" light going on. Nothing else. What does flash mean? Is it like a recall or something? Does anyone have the phone number for GE so I can ask them about this? Is there a part called a "spark module" and where is it located?
#5
Posted 22 May 2005 - 06:04 PM
#6
Posted 22 May 2005 - 06:22 PM
#7
Posted 23 May 2005 - 06:05 PM
I read lots of posts about the problems I am having. Almost all of them mentioned replacing the igniter. So that "seemed" like the thing for me to do. Well it seems obvious that wasn't my problem. No it wasn't glowing before I pulled the old one out.
Ron,
I wrote the number for GE down and I will ask them tomorrow about the service flash.
I will keep updated about what happens.
Thanks both of you.
#8
Posted 24 May 2005 - 07:14 AM
#9
Posted 24 May 2005 - 12:48 PM
1st of all, don't even bother calling GE for anything if your stove is a Kenmore. They told me they couldn't help me with anything at all because it is labeled a "Kenmore".
Now after 6 phone calls to basically computer answering/options and a few people who were clueless, I finally ended up with a guy that knew something. First thing he told me is that the Service Flash would not be my problem. After 10 years of no problems he highly doubted that would be it. He suggested maybe the Regulater (valve?). Not the thermostat in the oven either.
I have borrowed a tester to check power to the igniter now but am unsure of how to use it. Maybe someone can tell me. Here is the info of what I have. It is a Fluke brand 77/AN multimeter. It has 7 diff option to set the knob at. Which one do I use? Do I plug the diode (or whatever you call the wires from it) into the 10A plug or the 300mA? Now where do I touch on the stove to get the reading I need and what should it read? Does the oven cycle need to be turned on (I am guessing yes because that seems obvious).
Maybe someone can instruct me a bit because I am not very electronically inclined but am not afraid to try.
We are afriad this stove is going to knickle and dime us to death now. Maybe I should just make the service call but I thought this would be an easy fixit problem. Not turning out this way.
thanks
#10
Posted 24 May 2005 - 01:19 PM
#11
Posted 24 May 2005 - 05:24 PM
#12
Posted 25 May 2005 - 03:06 AM
I checked the wires as you said. I turned the dial to the V but the curved line was next to it not over it so I figure that was the same. Black wire in the common plug and red in the red V plug. Oven was on and the reading I got was 11.02 VAC. If I checked the wires without the oven turned on I get 7.08
What next?
thanks
#13
Posted 25 May 2005 - 03:45 AM
#14
Posted 25 May 2005 - 04:35 PM
Which one is ohms on the multimeter? I have a V with a squiggly line, a V with a solid line with dashes under it, 300mV with the solid line and dashes, an upside down horsehoe looking thing, an arrow connected to a plus sign, an A with a squiggly line and lastly an A with a solid line and dashes. I don't know which one to try. I'll check back in a little while.
thanks
#15
Posted 25 May 2005 - 04:42 PM
Is that right?
#16
Posted 25 May 2005 - 04:57 PM
#17
Posted 25 May 2005 - 05:26 PM
#18
Posted 25 May 2005 - 06:18 PM
So I imagine that the readings I got were correct as Ron had said.
Is there a way I can check the control (behind the dial?) with the multimeter?
Ron and Pegi you have been a great help so far and it is greatly appreciated.
#19
Posted 25 May 2005 - 06:21 PM
#20
Posted 25 May 2005 - 06:36 PM
