Frigidaire PLHS269ZCB4 evaporator fan not running after a while
#1
Posted 07 May 2006 - 03:41 PM
I looked up some very useful information on this website, but sitll can not sure what is the problem.
Here is what I did and what I found. My food compartment start to get warm couple days ago and it is also warm on the top part of the freezer. I unpluged the whole thing for a day. After I plugged it back, everything seems to work for 11 hours (evaporator fun is running fine, damper door is open, compressor is working.) Then, I guess tempreture reached certain level so the evaporator fun stopped and damper door closed. But after that, the evaprator fun never come back running again even though the damper door is open. Since the fun is not running, my food compartment is getting warm and also the top part of the freezer.
I read some posting on this web site, and think maybe this part will fix my problem,
http://www.repaircli...?R=154&N=948779
but just not sure about this. I guess I have couple question here:
1. I am not sure which part actually control the evaporator fan.
2. I guess the problem could either be the Thermometer or the fun control, right? How can I test which part actually is faulty?
Thanks a lot for the help.
#2
Posted 07 May 2006 - 03:53 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 07 May 2006 - 04:10 PM
Thanks a lot for your help. --Alan
#4
Posted 07 May 2006 - 04:34 PM
#5
Posted 07 May 2006 - 05:54 PM
#6
Posted 07 May 2006 - 07:03 PM
#7
Posted 08 May 2006 - 04:40 PM
#8
Posted 08 May 2006 - 04:47 PM
#9
Posted 08 May 2006 - 05:03 PM
Does not seem to find it in the image though.
I plugged in my refridgrator this afternoon and now still running ok, I am waiting for the problem to happen and then will take a test.
#10
Posted 08 May 2006 - 05:09 PM
#11
Posted 08 May 2006 - 07:10 PM
#12
Posted 08 May 2006 - 07:21 PM
#13
Posted 09 May 2006 - 03:16 AM
Thanks. --Alan
#14
Posted 09 May 2006 - 05:39 AM
#15
Posted 14 May 2006 - 04:19 AM
Thanks a lot for you guys help.
#16
Posted 31 October 2007 - 01:32 AM
Now I am really worried that I am not sure when it will break again even thgouh I change the control housing does not seem to completely solve the problem. I start to wonder may this be a loose wire on the evaporator fan or motor? How can I get to the motor? do I have to take out the back of the fridge to access it? Does anyone see similiar problems or does it sounds like a loose wire issue?
thanks.
#17
Posted 31 October 2007 - 01:33 AM
#18
Posted 01 November 2007 - 01:41 PM
www.eliteapplianceservice.org
#19
Posted 01 November 2007 - 01:54 PM
#20
Posted 02 November 2007 - 12:30 AM
http://www.fixitnow.com/beerfund.htm
