Calypso Washer
2 replies to this topic
#1 Lurker_divecr@yahoo.com_*
  • Lurking at the Threshold
Posted 21 May 2005 - 02:32 PM
Ok so my wife has washed a bathroom rug in our washer and it came to pieces.  LD code and won't drain.  It is now half full of water.   If I take it out back in the yard, should it be fairly easy to unblock the pump by turning it over and going thru the bottom?
#2 Ron
Ron
    Kohai
  • Appliantologist
  • 368 posts
Posted 21 May 2005 - 02:47 PM
Just tip it back,  drop the bottom panel and the pump is on the right.   2 clips hold it on.  Remove the clips and drop the pump.  When you remove the hoses your going to have a lot of water comming out.   See if you can clear the pump...Ron
#3 divecr
divecr
  • 1 posts
Posted 21 May 2005 - 03:28 PM
Thanks Ron!  I just wanted to make sure I didn't tilt it the wrong way and get any H20 where its not supposed to be.  I will try it.  Nathan  :)
