Inglis dryer no heat
3 replies to this topic
#1 partsman
partsman
  • 3 posts
Posted 04 April 2005 - 08:10 PM
Have an old Inglis electric dryer type 1. I believe they call it, I believe it is 1976 or so, it suddenly stopped putting out heat, I am sure the element was replaced once before and still seems to be in one piece, but tried to test all the other components but not sure if I am doing it right.
It is a G033100 Serial number EA10349, any ideas out there?
  • 24,288 posts
Posted 05 April 2005 - 06:44 AM
Got a good set of basic checks to do on this problem:
http://fixitnow.com/...-but-doesnt.htm
Start there and tell us whatcha found.
#3 partsman
partsman
  • 3 posts
Posted 05 April 2005 - 07:35 PM
Well after taking the timer out and breaking the knob to do it, because I thought that was the problem, I took another look down where the centrifugal switch is and I find a broken wire while poking around, guess that is the problem.
Will let you know later, and thanks for the suggestions.
Mine was a removable centifugal switch, but did not have to remove it, looks like the wire must have been frayed and as it broke it burned off.
So hopefully I just have to make a new wire with connections on it and it will be okay.
#4 partsman
partsman
  • 3 posts
Posted 06 April 2005 - 08:53 PM
Well took pictures of wiring to be able to put the timer and everything back together, could not get the computer to read camera card,:( so winged it a bit, put the burnt wire I repaired back on to the main power terminal and the other end to the centrifugal switch, then hooked up the timer, and DUH, bright spark:shock: when I plugged machine in, so took a little figuring and got it right this time and dryer is back up and running.:)
Just have to replace the knob I broke, they don't have them anymore, have to go to a recycle place where they repair old stuff.
So thanks for the help, good to know this site is out there, have recommended it to a few now.
