  • Announcements
Guitar Charlie
Noisy new Whirlpool washer
12 posts in this topic
Greetings,
I have 1.5 year old Whirlpool toploader that was always pretty quiet started making a loud humming noise in any cycle, except the filling cycle.  It still works far as I know, spins etc. but really gotten loud all of a sudden, it sounds like a garbage truck compacting garbage or like a fork lift.  Model #SM8525079
Any suggestions?
Might be motor hum.  Open it up and locate the source of the noise.
What is motor hum? This washer all of a sudden sounds like a garbage disposal.
Now it won't drain and the motor is burning up!
That is not a valid model number, looks more like the serial number.  Re-post the right number.  You could have something in your pump or a bad transmission or a broken motor, but have to wait for the right number.  I
I found a baby sock in the drain tube!  That was the problem, hopefully the machine didn't get trashed by not being able to pump the water out.  Question: When putting the 2 pins back in the plates do I need to go through all three holes or just the bottom two, there is a plastic cup that sits on the bottom plate.
Thanks!!!
Doh!! Shipping pins, never mind!!!
Now it's shaking like a SOB during the spin cycle, I didn't remove nything but I did have the washer upside down for a little while.  Any thoughts?  All the springs were in place, maybe those pins do do something..?
Hey Charlie,
See my post about Titled "Kenmore/Whirlpool direct drive suspension"(or something like that) from the other day.
Should be on page 2
Bill McK.
P.S. Mine had 3 pins
The three pins in the plastic cups are shipping pins and are to be removed.  If you had your washer laid over or upside down or bumped it up some steps or something your triangle slide plate could be out of place or you broke off one or more of the 3 brown glide tabs from the base that plate slides on.  Or one of your rear feet is stuck down while the other one is stuck up.  Make sure they are free moving.  Why on earth did you have your washer upside down......the whole case comes off from the front in 2 minutes, max......still waiting for a valid model number..........
Fixed it, dialed in the plate and she rruns like new.  I had no idea how easy it is to take off the front cover, live and learn!
Charlie
Welcome  :)
