Whirlpool gas oven "low" heat
#1
Guest_mavsfan_*
Posted 22 May 2005 - 06:05 AM
Reading through all the online help forums, this doesn't seem too typical of a bad ignitor. Seems like when those go bad, they'll never ignite, or take a rather long time to do so. I thought the gas valves are either all the way open, or all the way closed, depending on the current draw through the ignitor. I'm leaning toward replacing the gas valve.
Any thoughts/advice/nuggets of wisdom on this?
#2
Guest_mavsfan_*
Posted 22 May 2005 - 06:06 AM
#3
Posted 22 May 2005 - 07:56 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#4
Guest_mavsfan_*
Posted 22 May 2005 - 09:31 AM
The top burners all behave okay.
#5
Posted 22 May 2005 - 12:23 PM
#6
Posted 22 May 2005 - 02:07 PM
#7
Guest_mavsfan_*
Posted 22 May 2005 - 02:52 PM
The other weird thing is most parts catalogs on the internet point me towards the round type of ignitor. The one installed in the oven is clearly the square type. I took a close look at it, and it resembles the square ones. Do manufactures always use the same type, or can they mix and match these, assuming its matched up with a valve that will work with the ignitor? This part hasn't been replaced before at all, so whatever is in it was what the factory put in it..
#8
Posted 22 May 2005 - 06:44 PM
#9
Guest_mavsfan_*
Posted 26 May 2005 - 02:53 PM
I was surprised how easy it was to change out. I was expecting the oven to put up much more of a fight!
#10
Posted 26 May 2005 - 06:10 PM
